CAN you dig it?
CAN you dig it?
Getting pieces together to play with the canbus capabilities on the MS. Moreso for datalogging various this and that, but ideas are rolling in.
Specifications
Microcontroller: ATmega2560
Operating Voltage: 5V
Input Voltage (recommended): 7-12V
Input Voltage (limits): 6-20V
Digital I/O Pins: 54 (of which 14 provide PWM output)
Analog Input Pins: 16
DC Current per I/O Pin: 40 mA
DC Current for 3.3V Pin: 50 mA
Flash Memory: 256 KB of which 8 KB used by bootloader
SRAM: 8 KB
EEPROM: 4 KB
Clock Speed: 16 MHz
I/O for days!
Specifications
SRAM: 8 KB
EEPROM: 4 KB
Clock Speed: 16 MHz
I/O for days!
- DA6BF5D2-E5F4-4507-982A-2EABCCAF847A.jpeg (108.79 KiB) Viewed 1741 times
Re: CAN you dig it?
Probably a large part of the project will be to cook up a suitable enclosure with connectors/strain reliefs robust enough for (I'm guessing) the cabin of a car.
Will you use the Arduino IDE, or will you be programming on bare metal?
Re: CAN you dig it?
Enclosures are pretty easy anymore. I either draw something up from scratch or in most cases, find an existing drawing somewhat close and modify to fit my needs. Not sure what I’m doing for connectors just yet.
I’ve had good success with IDE.
- 6997A4D7-6945-4E80-BD07-2ABFDCB25434.jpeg (149.35 KiB) Viewed 1723 times
- BAC3D97F-00FE-44FD-A1D4-1A9F288680C7.jpeg (142.79 KiB) Viewed 1723 times
Re: CAN you dig it?
Oooh, a 3D printer. I'm sure it's a handy tool to have.
Re: CAN you dig it?
Yeah, it’s saved the day on a number of occasions.
Re: CAN you dig it?
For an enclosure, my easy button would be McMaster.
Snazzy stuff; custom CANBus architectures is the future of hot rodding.
There's a WHOLE LOT of documentation out there about GM CANBus, but their modules only do specific things. There's a bunch of profe$$ional motor$port grade $tuff that can do ABS and similar data via CANBus...
I've been curious about doing real time tire temperatures. A bar near the face of the tire could hold IR temp sensors that could give real time inner edge/center/outer edge temperatures. Mount another one in the dust shield reading the surface of the rotor for brake temperatures. Would they work in the rain? Maybe?
Re: CAN you dig it?
The Dark Side of Will wrote: ↑Mon Aug 24, 2020 12:54 pm For an enclosure, my easy button would be McMaster.
What about *in* the tire? There’s a video going around where the guy actually managed to fit a gopro on the wheel and mount the tire over.
Re: CAN you dig it?
Hardware to do that is super cheap from china, I may have bought some years ago on small break out boards.The Dark Side of Will wrote: ↑Mon Aug 24, 2020 12:54 pm For an enclosure, my easy button would be McMaster.
https://www.mouser.com/new/melexis/mele ... ermometer/
Re: CAN you dig it?
A complicated programmable part with a 52-page datasheet (possibly containing errors)... and it's in an old-school metal can.FieroWanaBe1 wrote: ↑Wed Aug 26, 2020 7:46 pm https://www.mouser.com/new/melexis/mele ... ermometer/
I suppose that the heating (via friction) and cooling (convection) of the tire tread happens on the outside, so wouldn't readings on the inside be a poor proxy of the external temperature, given the thickness of the tread?Honest Don wrote: ↑Wed Aug 26, 2020 5:44 pm What about *in* the tire? There’s a video going around where the guy actually managed to fit a gopro on the wheel and mount the tire over.
Re: CAN you dig it?
I can dig it quite a bit. I'd be very interested in a CAN-bus gauge controller that could drive all of the factory gauges via MS-CAN, thus eliminating all of the redundant wiring in the console. I'm going to try and do this with a microsquirt, but I don't think it will be able to carry all of the gauges by itself.
Re: CAN you dig it?
There's also the gpio board if you're brand loyal.ericjon262 wrote: ↑Sun Nov 22, 2020 6:24 am I can dig it quite a bit. I'd be very interested in a CAN-bus gauge controller that could drive all of the factory gauges via MS-CAN, thus eliminating all of the redundant wiring in the console. I'm going to try and do this with a microsquirt, but I don't think it will be able to carry all of the gauges by itself.
I'm mostly using this for additional data acquisition (trans temp, line pressure, coolant pressure, etc.) and maybe drive a few bright idiot lights that will hopefully get my attention before things go too wrong.
Re: CAN you dig it?
it's definitely something I'm going to start researching soon, I don't think that the microquirt is really ideal for what I want it to do, but it does offer other things that I would later like to implement into my car. when I have the car running, I'll start worrying more about getting the controller developed.Honest Don wrote: ↑Thu Dec 03, 2020 2:09 pmThere's also the gpio board if you're brand loyal.ericjon262 wrote: ↑Sun Nov 22, 2020 6:24 am I can dig it quite a bit. I'd be very interested in a CAN-bus gauge controller that could drive all of the factory gauges via MS-CAN, thus eliminating all of the redundant wiring in the console. I'm going to try and do this with a microsquirt, but I don't think it will be able to carry all of the gauges by itself.
Re: CAN you dig it?
300psi sensor from Low Doller Motorsports. $35 and comes with a calibration chart.
- 56C57E60-78D3-484C-813F-2E7A83703ECE.jpeg (119.8 KiB) Viewed 1394 times
Re: CAN you dig it?
I'm using these same sensors on my car for fuel pressure and oil pressure, just at 100 PSI and not 300. so far they seem ok.Honest Don wrote: ↑Sat Apr 24, 2021 5:35 pm 300psi sensor from Low Doller Motorsports. $35 and comes with a calibration chart.
