Anyone know the axles required for a swap from a THM125 to a 4T65 transmission using the stock rotors and suspension for a 1985?
Driver side 4 speed manual axle on the passenger side and a driver side automatic Pontiac 6000 Left axle on the 4T60e driver side?
Easy enough to measure and check. Just asking anyone with previous experience.
Which Axles Required for Swap from THM125 to 4T65?
- CaptainHindsight
- CaptainHindsight
Re: Which Axles Required for Swap from THM125 to 4T65?
For the Non-HD it is the Fiero Automatic drivers side in the Drivers side and a Fiero Manual Drivers side in the Passenger side.
Sounds easy enough. Welcome back!
