fuel tank bulkhead connectors.
as you may know I've been hunting for a solution to the tiny pins in the fuel tank bulkhead connector.
so far, I've machined some UHMW plastic to pass through the wires, I don't really like this because it doesn't actually seal.
I found this:
http://www.radiumauto.com/Bulkhead-Fuel ... -P682.aspx
but it's way to tall to fit in the tunnel...
Does anyone have part numbers for comparable Amphenol connector with a right angle top? it only needs to have 2 wires, although 3 would be preferred. I've been digging through Mousers parametric search with minimal luck.
and for the "it's fine put it together" crowd, this is out of a buddies car with a 255 LPH pump, I'm not a fan of toasted wires in a fuel tank, he was lucky it just blew the fuse.
Re: fuel tank bulkhead connectors.
I was directed to this by a guy on GRM, while the terminals don't appear to be larger, there are more available to transmit power, so I can run power through two or more terminals. it also uses larger wire, which increases the capacity of an individual terminal by allowing the wire to act as a heat sink for the terminal. I think it will work, but I will need to figure out a hold down, should be a cake walk.
https://www.racetronix.biz/p/universal- ... y/bcws-001
Post results. This is also on my to do.
If you want to use all four pins of the Racetronix connector for the fuel pump, I would suggest locating the splice points (where the single feed/ground wire splits into 2x 14 AWG) as far away as possible from the connector (like 2+ feet distance).
From the splice point, the 14 AWG wires should have equal lengths until the Racetronix connector. The idea is to have sufficient (and equal) resistance in each branch, to promote 50-50 load sharing between both contacts. We don't really know how well the contact resistance will be matched between contacts, so it is wise to implement some external ballast.
I like these parts-sourcing challenges.
How about this?
http://www.radiumauto.com/Electrical-Bu ... P1049.aspx
You might need to braze washers onto the sending unit top to meet the panel thickness requirement.
ericjon262 wrote: Wed Jan 05, 2022 1:57 pm as you may know I've been hunting for a solution to the tiny pins in the fuel tank bulkhead connector.
It looks like the in-tank connector has 4 cavities... is that accurate or am I confusing the terminal tool access for terminal cavities?
Maybe there's a 4 wire substitute for the top piece only?
I was looking at these:
https://www.ebay.com/itm/381011744617
That racetronix setup is pretty slick if it directly replaces the GM piece.
Emc209i wrote: Wed Jan 05, 2022 4:33 pm Post results. This is also on my to do.
Will do. The part should be here later today, I'll take detailed pictures comparing it to stock parts.
pmbrunelle wrote: Wed Jan 05, 2022 5:08 pm If you want to use all four pins of the Racetronix connector for the fuel pump, I would suggest locating the splice points (where the single feed/ground wire splits into 2x 14 AWG) as far away as possible from the connector (like 2+ feet distance).
How about this?
those may work, as you mentioned though, they will require something to take up the additional thickness.
Thats a good idea for the parallel branches, I'm not sure the the load share needs to be exactly 50/50, but it wouldn't be much good if it's 20/80 or worse.
The Dark Side of Will wrote: Thu Jan 06, 2022 8:47 am It looks like the in-tank connector has 4 cavities... is that accurate or am I confusing the terminal tool access for terminal cavities?
like this?
https://www.racetronix.biz/p/fs-bulkhea ... way/bca-4w
also
https://www.racetronix.biz/p/connector- ... de/rcs-061
also
https://www.racetronix.biz/p/connector- ... wa/rcs-058
I really don't like the pull to seat connectors, if I was more patient, I would order some GT 150.2 connectors to replace the metri-pacs
originally, I was going to order individual parts, but I started thinking that by the time I source comparable wire, and make it, it was worth the extra $35 to get the kit.
Honest Don wrote: Thu Jan 06, 2022 9:53 am I was looking at these:
I have the same part, or something very similar, on my current tank. I'm not too wild about it, it doesn't look like it seals as well as I would hope, the Racetronix part is an actual GM part, I have 99% confidence that it will be a drop in replacement, and because it's an OEM part, it met some kind of endurance/safety rating at one point. it's also much lower profile than the "seal" you linked to.
ericjon262 wrote: Thu Jan 06, 2022 10:04 am
like this?
also
also
Yeah, that was what I was asking about... looks like the in-tank connector is the same (similar? compatible?) connector the Fiero tank has stock, which is cool.
sorry, I didn't answer that part, yes, the stock in tank connector has 4 positions as well, but only 2 are used. I would bet the above linked part is a direct replacement.
ericjon262 wrote: Thu Jan 06, 2022 10:23 am sorry, I didn't answer that part, yes, the stock in tank connector has 4 positions as well, but only 2 are used. I would bet the above linked part is a direct replacement.
Probably form/fit/function replacement... you mention pull-to-seat pins. I don't think those existed in the '80's.
Replace which Metri-Packs? The external tank connector *looks like* a Metri-Pack to me.
The Dark Side of Will wrote: Thu Jan 06, 2022 10:27 am Probably form/fit/function replacement... you mention pull-to-seat pins. I don't think those existed in the '80's.
They were being phased in during the late 80's. IAC's, TPS's, and CTS's were the first parts I am aware of to use them, this particular connector is for an F body fuel tank, not sure of the year, but I would guess in the 90-97 range
The Dark Side of Will wrote: Thu Jan 06, 2022 10:30 am Replace which Metri-Packs? The external tank connector *looks like* a Metri-Pack to me.
the male connector (which has female pins), some delphi GT connectors were designed to be replacements for Metri-pac pull to seat connectors.
https://www.bmotorsports.com/shop/produ ... cts_id/799
https://www.bmotorsports.com/shop/produ ... cts_id/835
That being said, I have not investigated the current capacity of these connectors.
ericjon262 wrote: Thu Jan 06, 2022 12:05 pm the male connector (which has female pins), some delphi GT connectors were designed to be replacements for Metri-pac pull to seat connectors.
That's a good tip, I didn't know about that.
Among the other Metri-Pack 150.2 pull-to-seat connectors found in the Fiero, the V6 ignition module uses the 150.2.
The snap clip on its connector broke off (old brittle plastic), so I cut the wires shorter to put on another Metri-Pack 150.2 pull-to-seat.
I thought to myself, this isn't so good if every time I service the connector the wires get shorter. I don't leave service loops in my car like I do on my house.
ericjon262 wrote: Thu Jan 06, 2022 12:05 pm That being said, I have not investigated the current capacity of these connectors.
Current capacity roughly goes with the width of the blade.
Do you have the Delphi/Aptiv pdf catalog? Current ratings can be found in the catalog.
pmbrunelle wrote: Thu Jan 06, 2022 6:15 pm
Glad I could provide a useful tidbit. both the metri-pack 150, and GT 150 connectors use 1.5mm blade widths, so I imagine the capacities are comparable. I don't have a catalog.
photo dump in progress.
unpacking:
an assortment of shinkboot, some silicone grease, and a bit of solder is included.
for some reason, they couldn't provide the same color wires inside and outside of the tank, but there's only one thats different (purple vs gray)
the wire itself appears to be high quality.
the connector
it's worth noting that the internal plug can be inverted be careful to make sure your wire designations are what you think they are. the lock plate can be installed either way as well.
the part has an inspection sticker on it, with clearly legible data.
I haven't got around to doing anything with it yet other than pictures, I'll provide further information when I get it put together. FWIW, if you have an earlier car, this is what the tank connector looks like, I suspect it has a higher capacity than the later connector.
ericjon262 wrote: Fri Jan 07, 2022 2:38 am I don't have a catalog.
Download this:
https://www.powerandsignal.com/docs/DCS ... atalog.pdf
I found the GT pull-to-seat replacements on page 22 of the pdf.
Browsing ballenger motorsports for some relays, I saw this:
https://www.bmotorsports.com/shop/produ ... ts_id/5098
https://www.bmotorsports.com/shop/produ ... 7B50%7D248
https://www.bmotorsports.com/shop/produ ... ts_id/5163
The terminals in the kit are about 3x larger than the racetronix part with a total of 6 positions! I'm ordering one and if it fits on the sender, may use it instead of the racetronix part.
Damn dude. You need this more than bulkhead connectors
Shaun41178(2) wrote: Wed Jan 19, 2022 10:43 pm Damn dude. You need this more than bulkhead connectors
Dirty hands, clean money.
https://youtu.be/5IOXzpRJ714
You watched me wash em
I guess it's easy enough to see when Shaun is bored.
