Brake system hydraulics.
Posted: Thu Nov 09, 2023 10:08 am
Specifically, the combination valve and master cylinder.
My understanding is that the combination valve is supposed to shift to isolate the front or rear brakes in the event of a blown hose, however, I thought this was also the whole idea behind modern master cylinders having tandem pistons, each piston feeding half of the brakes, front or rear. Yes most brake master cylinders have a common reservoir that can be drained, but they're typically divided midway up such that a leak on one side doesn't drain fluid from both.
The whole system seems very belt and suspenders, not that it would be a bad thing to have redundancy, but I just don't see the advantage.
is my understanding grossly flawed? the reason I ask, is because I'm planning on installing a line lock, and was considering an adjustable proportioning valve in the rear circuit, and eliminate the combination valve from the equation. Am I making a grand mistake by doing this?
