MAP controlled pcms are "better" right? Atleast thats what I allways thought.
Now reading through my SAFC2 manual it mentions "hotwire" systems (which i assume is a MAF) and it seems that MAF systems have a slight advantage as far as tunability.
Am I drunk?
Heres a "omg your an idiot...go post on Old Europe" question...Can you run both a MAP and a MAF.
Just seems to me that running a pressure and a flow sensor would be a good thing.
MAP vs MAF
MAP vs MAF
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
1991 Skyline GTR
(OO\ SKYLINE /OO)
you can run both. Many cars do it today as a matter of fact.
THere is a reason why many cars use Maf today. Its more accurate in determining how much fuel should be added
Map systems are good for boost. A lot of the supra guys ditch the Maf setup and run a Map setup.
You want to set up your safc to run off a pressure sensor Ie Map sensor.
I have instructions here on how to hookit up and such. also tehre is a post on 60 degree about it. I think in the DOHC section. It should stick out. SAFC is in the title. I saw some diagrams in there on it. And I can tell you how to progam it to work on our engines once you get it wired up.
Thanks Shaun.
I saved the pic of the wiring from the 60 degree post. I also posted there to get his feedback. Probably wont have time to wire it up till the spring. Ill keep you posted. Nice thing about the Safc is that it will help a non boosted motor also.
1991 Skyline GTR
(OO\ SKYLINE /OO)
1991 Skyline GTR
(OO\ SKYLINE /OO)
Running both MAP and MAF is a function of software. '94 and newer LT1 electronics and LS1 electronics use both MAF and MAP. They compute and initial fueling solution with the MAF, then cross check MAP base fuel solution. If MAF fails, they fall back to MAP. That's why you can unplug the airflow meter from a Camaro and it turns on the SES light, but a Mercedes with unplugged airflow meter is virtually undriveable.
But you can't do both unless you have an ECM that understands both.
