The results are in........ Northstar dyno
Before and after 80mm throttle body. Took 5 runs, best 1 before compared to the best 1 after.
gained 10ft-lb torque... not too shabby.
Where'd you get the idea that the auto sucks up 25%?whipped wrote:300. Through lossy auto tranny = 341 at the crank. I'd probably be putting 300 to the wheels with a getrag...
What you have there is about what I would have expected for a 275
engine through a 5 speed.
Running 4T60? 440T4?
Nice smooth curves... looks like it's in pretty good tune.
Last edited by The Dark Side of Will on Wed Feb 01, 2006 3:12 pm, edited 2 times in total.
4t80e. 25% is the MINIMUM value I've heard for it. I've heard upwards of 28% on stock cars going to the dyno.The Dark Side of Will wrote:Where'd you get the idea that the auto sucks up 25%?
What you have there is about what I would have expected for a 275 engine through a 5 speed.
Gotta have the beef for when I up the power. :thumbleft:
Aren't you running the 730? What are you using to control the trans?
I don't see that the 4T80E would be that much lossier than any other GM transverse auto. There's more mass to spin, but not any more mechanism. You're using stock manifolds, right? I also find it a little tough to swallow that a CAI and manifold-back exhaust would be worth 40 HP.
Anyway, good numbers. If you can get it to hook up you should be able to run 13.0 with that transmission and cut a 1.7 short time on street tires.
Last edited by The Dark Side of Will on Wed Feb 01, 2006 3:16 pm, edited 1 time in total.
The problem is the 80e has like 3 (4?) parasitic power draining pumps. I'll try to find the dyno's of the stock northstar cars. Remember I'm probably running higher timing than stock, and definately running leaner than stock, so that probably has a lot to do with it. Oh, and I don't have to deal with any MAF restrictions.The Dark Side of Will wrote:Aren't you running the 730? What are you using to control the trans?
stock dynos:
http://www.caddyinfo.com/northstardyno.htm
so using the best test, 21%, it's 326 at the crank
Ryan this is awesome dude. Those are good numbers. Just wanted to say congrats. 7730 tuning masta!!
paddle shifting tranny and all. Kickass setup.
Just an FYI, Whats his name with the nstar convertible on Old Europe with a bone stock n star(300hp) through the 4t80 layed down 240 whp. Thats about 20%
So 256 is pretty good for the mods you have and the computer. Seems you are doing a really good job with that computer. Nice work man.
Pics and or vids?
Pics and or vids?
By any comparison, the stock exhaust manifolds on the N* aren't that bad at all. I'd go as far to say they are good...
That is a devilish power curve. Awesome low end, and it pulls harder and harder and harder. It's amazing how much better the curve is all around than the 3.4 DOHC (In respect to displacement of course). That is a damn nice setup.
Thanks. Do you know if he had a k&n type filter or anything? Seems like a waste to install the stock caddy air filter box. If he gained 10hp there, 230whp would be 23%... I think the real loss is somewhere between 21-26%... I could believe an average of 23ish..Shaun41178(2) wrote:Ryan this is awesome dude. Those are good numbers. Just wanted to say congrats. 7730 tuning masta!!
Pics and or vids?
Oh, and I was going to bring the videocamera, but have no idea how I'd bring it into the computer. I don't have one of those video capture cards.
