Diagnosing another no start condition..
I had just gotten back from a test drive to see fi my new trunk was going to heat up and burn.. everything looked okay so I backed out of the driveway to go for a longer drive and then my engine stalled. It won't restart. ARGH!
I just went through this same problem from a bad injector ground. I now have all new grounds, so that's certainly not it. The engine cranks normally, battery voltage is good, fuel pump turns on, there's fuel pressure, the tach works (getting ignition pulses; the CPS must be working), the ECM is picking up ignition pulses (I'm seeing RPM data on the scanner) and all sensor readings check out fine on the scanner.
The only thing peculiar I noticed was that Integrator stays at 0 while I'm cranking. Wouldn't that mean the ECM has decided to NOT fire the injectors for some reason? Any ideas?
Honestly dude, that sounds like a 3.4 DOHC to me.Series8217 wrote:This POS decided to start without me doing anything. :mumum:
I'm going to go over ALL of the wiring tomorrow. These gremlins are pissing me off!!
What year injectors are you running?
My car used to do the same thing with the factory 91-93s. Even after the new chip, raised idle, and everything else (INCLUDING the new injectors), it'd still die once in a while. When it did, it would usually not restart immediatly. But 5 min later, while starting it, I held the throttle wide open, and after trying a couple times it started right up. I still don't know what it was, just thought it came with the territory kinda thing.
91-93 injectors. You did nothing but change to the later ones and it fixed the problem?Aaron wrote:Honestly dude, that sounds like a 3.4 DOHC to me.Series8217 wrote:This POS decided to start without me doing anything. :mumum:
I'd bet a lot of money that is your problem. The 91-93 injectors are known for being responsible for the "phantom stalling" problem. In the stickshift w-bodies, they would stall whenever you put the clutch in and slowed down, such as to come to a red light. This would happen nearly 1/3 of everytime you went to stop at a light. Even with my custom chip and raised idle it still stalled out. Usually when it stalled at a light, I was still moving and could just drop the clutch to get it to start again. But sometimes when I was just idling and it would stall, it wouldn't start again for a few minutes, and even then I had to hold it WOT.
All of these issues went away with the 96 intake swap, which included with it 96-97 injectors. If I were you, I'd swap to the newer injectors asap. And intakes, but we've already talked about that :thumbleft:
How could you possibly start the car holding it at WOT? That puts it in clear flood mode.. i.e. it doesn't fire the injectors.Aaron wrote:I'd bet a lot of money that is your problem. The 91-93 injectors are known for being responsible for the "phantom stalling" problem. In the stickshift w-bodies, they would stall whenever you put the clutch in and slowed down, such as to come to a red light. This would happen nearly 1/3 of everytime you went to stop at a light. Even with my custom chip and raised idle it still stalled out. Usually when it stalled at a light, I was still moving and could just drop the clutch to get it to start again. But sometimes when I was just idling and it would stall, it wouldn't start again for a few minutes, and even then I had to hold it WOT.
Will the later injectors fit in the early fuel rail? I'm not switching intakes..
Sounds to me like he had an intermittant sticking injector.Series8217 wrote: How could you possibly start the car holding it at WOT? That puts it in clear flood mode.. i.e. it doesn't fire the injectors.
GM MPFI injectors are pretty universal. I've got LT1( or something) injectors in mine.
Oh, btw, I had a 93 dohc that stalled as well. It was pretty much random, and only seemed to happen when I was pulling into a parking lot. I forced it to run rich by changing the minimum BLM value, and richening up the VE table. Never stalled after that.
My fiero is aliiiive!!
Don't ask me. This wouldn't be the first time you were wrong about the ECU though....like the max rpm....heheSeries8217 wrote:How could you possibly start the car holding it at WOT? That puts it in clear flood mode.. i.e. it doesn't fire the injectors.
Yah the injectors will fit and plug right in, their outside is the same.
Whipped, that is exactly waht most 91-93 3.4s do, with the 5-speeds being almost dangerous about it.
Crank PW multiplier vs TPS:Aaron wrote:Don't ask me. This wouldn't be the first time you were wrong about the ECU though....like the max rpm....heheSeries8217 wrote:How could you possibly start the car holding it at WOT? That puts it in clear flood mode.. i.e. it doesn't fire the injectors.
1.00 for 0-24.9%
1.06 for 25.0-87.4%
0.00 for 87.5% and up
Pretty much every EFI GM car has the clear flood feature.
Your motor may have been getting flooded and would start up on the residual fuel in the intake?
Anyway, I went over my wiring today and didn't find anything bad. My plug wires are routed pretty badly and could be crossfiring; I'm going to pick up some seperators tomorrow and keep them apart. Might clear up some idle misfires too, though I think thats mostly from the cam timing.
Could be, I'm not sure. I just know it used to help it start after it died. In fact, I've found a lot of times flooring a car helps it start. Helps my Fiero too. Maybe like a choke action I don't know.Series8217 wrote:Pretty much every EFI GM car has the clear flood feature.
I'm telling you, pick up a set of 96 injectors. If nothing esle, your motor won't sound like a diesel from the old ones anymore..Anyway, I went over my wiring today and didn't find anything bad. My plug wires are routed pretty badly and could be crossfiring; I'm going to pick up some seperators tomorrow and keep them apart. Might clear up some idle misfires too, though I think thats mostly from the cam timing.
Yeah, scanner shows injector PW to be like 5 or 6 ms (I don't remember off hand). I checked all the fuses with a fuse tester to make sure they don't only look good but are good.whipped wrote:So what's it doing? It just stalled and won't start now?
Can your scanner read injector PW?
Check the fuses.
I got it to start yesterday without touching anything.. but I'm still worried that its gonna stall and not start when I'm in the middle of nowhere on my drive back to LA on Sunday. I haven't tried to start it since... the battery is out because I'm rebuilding the front compartment and moving the battery as low and toward the rear as it will go in the front. I'll try it out tomorrow when the tray is done, to see if its being stubborn about starting again.
One of the injector fuses sends power through a C203 pin to the miniharness connector. Past the miniharness connector it splits into 6 power wires.. one to each injector.. they're parallel.. I really doubt the problem is past that point, since it wouldn't make sense that they all go bad. The miniharness connector was giving me trouble with the TPS a while back. Maybe the problem is in there; that has the injector grounds AND power going through it. I'll take a look..whipped wrote:I think you need to rewire your injectors. Just start from scratch, buy a new injector harness from the junkyard and go from there. Where are you getting power for your injectors from?
One? The stock fiero use 2 fuses 5 amps each, one for each bank.Series8217 wrote: One of the injector fuses sends power through a C203 pin to the miniharness connector. Past the miniharness connector it splits into 6 power wires.. one to each injector.. they're parallel.. I really doubt the problem is past that point, since it wouldn't make sense that they all go bad. The miniharness connector was giving me trouble with the TPS a while back. Maybe the problem is in there; that has the injector grounds AND power going through it. I'll take a look..
This is a <another> lie. Like someone else said, the fuel injectors are shut down when you floor the pedal and the motor isn't running.Aaron wrote:Could be, I'm not sure. I just know it used to help it start after it died. In fact, I've found a lot of times flooring a car helps it start. Helps my Fiero too. Maybe like a choke action I don't know.
Not a stock Fiero I followed the factory 3.4 DOHC wiring. It only uses one fuse. I put a 10A fuse in one of the injector fuse slots and use that for the power. The wire is the same gauge as everything else on the fuse box that uses 10A..whipped wrote:One? The stock fiero use 2 fuses 5 amps each, one for each bank.Series8217 wrote: One of the injector fuses sends power through a C203 pin to the miniharness connector. Past the miniharness connector it splits into 6 power wires.. one to each injector.. they're parallel.. I really doubt the problem is past that point, since it wouldn't make sense that they all go bad. The miniharness connector was giving me trouble with the TPS a while back. Maybe the problem is in there; that has the injector grounds AND power going through it. I'll take a look..
Aaron, I drove for 7,000 miles without any stalling issues like this. The injectors were cleaned and tested 7,000 miles ago. They don't just randomly go bad all at once. I think your car had other problems.Aaron wrote:I think he needs to buy newer injectors. Rather, I know.whipped wrote:I think you need to rewire your injectors. Just start from scratch, buy a new injector harness from the junkyard and go from there. Where are you getting power for your injectors from?
