As some of you may remember, I had a thread not too long ago about problems with a popping noise on my passenger side front suspension on Old Europe. I narrowed it down to the UCA slipping, and believe that that is the cause. This past monday, I ordered a paddle nut & bolt set from the fiero store. I got it today, and put it on. I tightened the nuts to 52 lbs + 1/4 turn, and the popping is still there. One observation, the bolts supplied were big enough to go right through the rear hole and have room to play, but the front one was a tight fit, I had to thread it through it. The bolt on the rear larger hole was loose when I went to loosen it (was tightened with an impact wrench a week ago at an alignment shop). So what i'm wondering I guess is, is this normal? I could try putting a larger bolt in the rear hole, but then I'd have to modify the paddle nut. Could I have it aligned, and then have the alignment shop tac the paddle to the crossmember?
or
Do I need a new crossmember? Maybe this is a good time to upgrade to HMS tubular xmember?
Thanks in advance for the help
88 Front Crossmember - Enlarged paddle nut holes?
New caliper, new rack bushing, tie rods are in good condition. The lower balljoint has been replaced, the upper bushings were replaced, and the wheel bearing was replaced. All this has happened within the past year on that side. The upper balljoint isn't bad, has been checked. I know that after the suspension starts popping after an alignment, my alignment goes bad real quick. 88's suspension is adjustable from the uca, and with the enlarged hole and the bolt being loose that was tightened extremely well that's attached to that enlarged hole, it just makes me wonder ya know. :scratch:
Update!!
Just went out there and painted it, did something that my alignment shop recommended doing (enlarged the crossmember hole that the bolt was having to thread through), and pulled out of my garage. ..... - POP - it did it again. This time I pulled it back into the garage, and what did I see? A big crack on the paddle shaft. That would explain it :thumbleft:
