Tech Link Library
Re: Tech Link Library
draven wrote: Fri Feb 23, 2024 12:30 pm Very decent article on running a returnless PWM pump with current fuel pump module functionality and how to reverse engineer when no room to fit a modern fuel module into the fuel tank... i.e. the fiero tank.
https://www.vaporworx.com/resources/pwg ... eturnless/
ZL1 Fuel pump module disassembly by vendor/author of above
https://www.youtube.com/watch?v=bclAKbGpdxo
I was reading that from where you linked it on Pfiffle. Good tech!
It has me wanting to run my system PWM.
On a long road trip, the Fiero center tunnel gets pretty hot. Some of that is from air that's passed over the radiator and gone under the car, but fundamentally the fuel tank is pretty warm in those situations.
Between a better fuel system design and venting the radiator compartment, there's probably a good bit that can be done to reduce center tunnel temps on long drives.
The Dark Side of Will wrote: Sun Feb 25, 2024 6:01 pm I was reading that from where you linked it on Pfiffle. Good tech!
Don't want to clog this thread with banter but see build thread :-D
Thorough engineering/manufacturing dimensional info on pipe threads.
Found when searching for pipe thread dimensions after discovering that OnShape does not incorporate pipe threads
https://www.machiningdoctor.com/charts/ ... pt-charts/
