Tech Link Library
SAE paper on fastening/attachment of sandwhich composite structures:
http://www.sae.org/technical/papers/700850
Chassis stiffening with urethane foam:
http://forums.freshalloy.com/showthread ... ost1383361
SCC article on the same thing:
http://www.sportcompactcarweb.com/proje ... index.html
ok guys my friend who created the squirrley performance turbo calc has been redoing it to make it more user friendly and power.
here is the new beta
so when calculating the turbo for your application this one will let you select multiple turbo maps and it will graph it on all of them for you to compare easily.
http://www.squirrelpf.com/~turbocalc/beta/
great gm performance parts descriptions and part #'s for s series engine internal parts
http://www.s-series.org/htm/tech/GMPerf ... 44-148.pdf
DIY Ion Sensing ignition:
http://forums.nasioc.com/forums/archive ... 94131.html
http://vvnet.fi/ville/ion/ion.html
http://www.fs.isy.liu.se/~larer/Projects/main.html
spark plug gap impedance sensing, ion current (search terms)
Fuel injector specs
http://users.erols.com/srweiss/tableifc.htm
Digitizing custom piping for later reproduction:
http://www.mandrelbend.com/content.asp?ContentId=795
Re:
More flow rates. I found some in here that the other was missing.lucky wrote:Fuel injector specs
http://www.fuelinjector.citymaker.com/p ... 782443.htm
Re: Tech Link Library
SEE WARNING BELOW!!!
http://www.smokemup.com/tech/an_thread_sizes.php
AN vs. SAE fitting comparison.
CAUTION: DO NOT confuse AN fittings with the standard FLARE fittings you can buy at the hardware store. While they will go together, the AN sealing face has a different angle (37 deg) vs. standard Flare fittings (45 deg). If you try to use an AN fitting and flare fitting with each other, the difference in the two sealing face angles can result in a leak. There are special flaring tools for jobs where AN fittings will be used. Standard flaring tools only do 45 deg sealing faces for standard flare fittings.The Dark Side of Will wrote:http://www.smokemup.com/tech/an_thread_sizes.php
AN vs. SAE fitting info
BMW DME tuning articles & info (references TunerPro):
http://www.ehow.com/how_4807313_tune-obd-bmw.html
WAR: Emulator & realtime tuning for BMW's:
http://millerperformancecars.com/war-chip.html
