Tech Link Library
Tech Link Library
Product1620 suggested a tech link library sticky, so here it is.
I'll start with the most informative page I've ever read about turbocharger characteristics:
http://www.turbominivan.com/tech/turbo201.htm
the best compilation of turbo maps i've found so far
http://www.hexfiles.com/resources/compressor_maps/
http://www.firebirdgt.com/formulas.html#Airflow_vs_HP
About a week ago I started a similar thread about turbochargers. For that specific information, it might be a good place to dump some of the links in this thread. But, as the mod it's up to you.
See this thread:
phpBB/viewtopic.php?t=3641
See this thread:
http://www.dohcfiero.com/Factory%20ECU.htm various info on dohc/tdc swap.
1998 Mustang GT
Carbon fiber info on honda tech http://www.honda-tech.com/zerothread?id=1033872
also see phpBB/viewtopic.php?t=4192
Thread about synthetic oils-http://realfierotech.com/phpBB/viewtopic.php?t=2877
1998 Mustang GT
turbo selection article.
http://www.smokemup.com/tech/turbo101.php
1998 Mustang GT
turbonetics matrix of engine size vs HP goal to size your turbo..
http://www.turboneticsinc.com/downloads ... Matrix.pdf
http://www.v-eight.com/tech_forum/index.php
It's *for* a Toyota engine, but they don't discuss specifics too much. A lot of it is general theory. It's a decent site.
found a superior turbo power calculator and mapper
http://not2fast.wryday.com/turbo/glossa ... calc.shtml
lot more variables - but thats how you make it accurate. it will even show you what siz einjectors you should be running based on the duty cycle
whipped wrote:The LT1 vette pump is good to about 400hp NA (probably more)... I think the typhoon/TTA pump is one you can use for boosted apps. I can't seem to find the fuel pump comparison page...
oh here it is:
http://www.gnttype.org/techarea/fuelsystem/pmprate.html
Need to figure out if your wheels will stick out?
http://www.1010tires.com/WheelOffsetCalculator.asp
86-87 front/86-88 back:
15x7 30mm
88 front:
15x6 37mm
15x7 30mm
88 front:
15x6 37mm
forgot that my friend has a custom written turbo mapping program on his site:
http://www.squirrelpf.com/turbocalc
outputs full graph displays if you want
click for example
click for example
GM wiring diagrams http://home.att.net/~subzero350/index.htm
1998 Mustang GT
Great turbo writeups, with equations.
http://www.turbobygarrett.com/turbobyga ... enter.html
:thumbleft:
:thumbleft:
