the TPS on mine would read a voltage if i reset it or not, but it would only go to 0% if i reset it by unplugging the connector at the ECU - it would idle high if it wasn't reading 0%The Dark Side of Will wrote: The scanner doesn't have a TPS % readout, just voltage. With a closed throttle it's around 0.68 V.
How do I get laid when my 2.hate has a high idle?
So with the IAC counts at zero it idles at 1800-2000 RPM. Is that the typical symptom off an EGR vacuum leak? What is the mechanism of this leak? I disconnected & plugged the EGR solenoid vacuum connections with no effect on engine RPM, so what I have is a BIG leak. The brakes seem to work fine, so I'm disinclined to suspect the brake booster.
the leak is usualy the tube that runs from the EGR mushroom to the bottom of the upper plenum. its very crumbly, and if you remove the upper plenum, it tough to do without breaking this tubeThe Dark Side of Will wrote:So with the IAC counts at zero it idles at 1800-2000 RPM. Is that the typical symptom off an EGR vacuum leak? What is the mechanism of this leak? I disconnected & plugged the EGR solenoid vacuum connections with no effect on engine RPM, so what I have is a BIG leak. The brakes seem to work fine, so I'm disinclined to suspect the brake booster.
