Fiero Autocross ownage
Just wanted to add that I have my air filter on top of an 84 plate there and it probably works better than just leaving an open cone right under the grill. Also, my engine bay hasn't gotten any bit noticably warmer. I can't say anything as far as drag or what not, but I'm satisfied with my mpg and the fastest I've ever takin the car is 110 at the strip. Other than that I might have gotten up to 80 once or twice, so I don't really care much about drag. I guess its one of those things were you either don't mind it or you hate it.
I am also using the stock 87 front bar with the stock 88 rear bar on the 88 rear suspension. I have the front koni's at about 3/4 full hard and the rea is at full hard. I also have 350lb rear coil over springs and 325lb front springs. I'm running 205/50/15 tires in the front and 225/50/15 in the rear. The staggered tires has helped the understeer a lot. There still is a little bit, but not much. Next season I think I might try a wider rear tire if I can find one. I will probably have to go to a 16" wheel.Jinxmutt wrote:Yea, but i have the 88 rear bar, and a factory front bar. That would make the rear bar larger, whereas your bars equal. Thats not counting the length of the arms like you mentioned.
As I said earlier, it could be my driving, I could be coming into the turns too hot, but I find that with my car at my current (lack of?) skill level, just about halfway through the turn my car switches to on the edge of understeer, to slight oversteer. Before I had the pzero on the front, all the car did was understeer, so it could also be a tire balance I need to work with.
SInce you have way more torque than I do, I would recomend you go as wide as possible on the rear, with a coresponding narrower tire up front. 275 in the rear and 255 up front might work nicely.
I got the results from the races that sunday..
http://drbiggly.com/racing/results/auto ... 06_raw.htm
I finished 78th, 5 seconds slower than the fastest car there.
