New PB at the Track
Posted: Mon Dec 11, 2006 6:21 pm
This was done on a 2.8" pulley and my mods are listed below. This was all done on street Nittos. Ran a crappy 1.89 60ft and my first pass went 12.09 @ 114.8mph. With some drag radials and a good launch the car should pull a high 1.6 60ft and hopefully run around 11.6's or 11.7s. Car was seeing 24 degrees of timing with no KR. I tried a few more passes and ran into some trouble with the car spinning like crazy on the 1-2 shift. I looked back at HP Tuners as I had just logged the run to see what was up and found out that it hit the rev limiter and saw around 6-7 degrees of KR for a few seconds as I had to let out. We are going to try and figure out how to adjust my shift points to make it so it doesn't have this issue of hitting the limiter and having knock.
-Amir
-Amir
