Sloooooowwwww Turn Signals or Blinkers!
Why are my turnsignals so slow? I got my alternator problem sorted out,I tightened the belt and the alternator and my volts gauge reads fine.Is there any way to speed them up a little? I leel like I need to give people behind me on the highway 5 minutes to make sure they see them flashing when I go to change lanes.Thanks :thumbleft:
The bulbs are wired in parallel. When one burns out the resistance goes up and the flash slows down. When you add extra bulbs to the circuit (like when pulling a trailer) the resistance goes down and the flash speeds up.
If all your bulbs are working, check for corroded contacts in the connectors through which the turn signal wiring goes.
You might also try replacing the flasher. An electronic rather than electromechanical flasher would be best.
