Ok now I know this is not the proper way to do this at all. That is stacking two head gaskets on top of each other to lower compression. I know using one gasket is the prefered method but of course that would be custom one offs
I dont' care about squish area and all that nonsense. I am not worried about detonation. I know honda guys do this with some success.
I just want to know the liklihood of the gaskets leaking. thinking of using 2 gaskets to lower compression by about a full point.
thoughts?
Running two head gaskets
make sure you use arp head studs and torque it down right or it will def. leak.
www.Cometic.com will make thicker custom gaskets
http://www.engine-parts.com/GMV6/GMV6int.html for arp head studs
Has anyone tried this on a 60 deg. v6 yet? Its common on vws and hondas.
