Fuel problem HELP
Fuel problem HELP
I have a v6 2.8 stock motor and it won't fire up and keeps choking. Then after a while struggle it will finally fire up (after lots and lots of engine turn overs) and lag like crazy acting like it's going to stall. If i give it gas it imidately stalls and if i try to wait it out eventually it will stall. the in tank fuel pump is new and the whole ignition system is too. Need some help to get my buddy on the road.
Silver 85 GT-scratch that
Maroon and sliver 86 GT
Project Life
Project Life
No but i'm getting the pressure sensor tomorrow. The EGR tub is a little loose but i don't think that's the problem. The car has progressivly gotten worse. how hard would it be to change or clean the fuel injectors. The car has been sitting for a while. Oh and when i get the pressure gauge what should my fuel pressure be?
Project Life
Project Life
yep replaced it to a new(er) distributor and redid the timing. With a fuel filter would it be lagging so much? it seems to be very bad. dosn't fire hi so i guess that could be it. it seems to fire light then normal then light. I'll check that. SO what should my fuel pressure be at?
Project Life
Project Life
I had two guys do it by ear. so i think timing is ok. I changed the fuel filter and it's gotten worse since then. It now dosn't fire up at all. Every once in a while it will fire but will not run. it used to be it would fire untill it was firing fast enough to start then run like shit, but now it dosn't come close to running.
Project Life
Project Life
You CAN NOT set timing by ear unless you have jumpered the appropriate pins in the ALDL connector. Did you do this?
The reason you can not is that the ECM will adjust timing to maintain idle speed. Jumpering the correct pins in the ALDL connector tells the ECM to hold timing static so it can be adjusted manually.
Also, timing by ear is not adviseable on an EFI engine because base timing is not what the ECM uses to control idle. The ECM can command the timing to advance or retard from base timing in order to maintain idle stability. You can not set the timing by ear with the ECM controlling it, and when you do set it by ear, the advance for best idle may not be the correct setting for base timing.
If base timing is off, then the ECM could be delivering more or less timing than it actually thinks it is.
So... exactly HOW did you set the timing?
wait you have to set timing from the electrical connector next to the cig lighter? What would you put the teeth at 5 degrees first then move the distributor till some connector tells me it's in place? so i need a timing light and there's no way around it?
Project Life
Project Life
You need to put a jumper (a short piece of wire) between two of the pins in that connector. This puts the computer into "field service mode" which means that it isn't doing anything with the timing. You can only set the base timing (turn the distributor) once that has been done. Yes, you will need a timing light.
Do you understand how the fuel injection computer controls ignition timing?
