Parts & Materials Library / Hard to Find Parts
I've been thinking that along with the Tech Link Library we ought to have a library of sources for materials, DIY parts and hard to find parts.
What I'd like to see...
  • Sources, prices & part numbers, where applicable, for DIY & Raw Materials like:
    • Tubing--steel & aluminum
    • Mandrel bends--both square and round
    • Rod ends--what kind & grade incl special features like grease fittings
    • Injector bungs--steel and aluminum
    • Springs--2.5" ID for coil overs
    • Reasonably complete listings of various kinds of fittings
    • Etc...
  • Sources, prices & part numbers for Hard to Find Parts like
  • I'm deciding about whether or not to include parts lists for special hybrid projects--for instance LS6 valvesprings into a Gen III/IV V6 (And sources for LS6 valvesprings).
What I'd rather not see:
  • Stock replacement parts, unless they're Hard to Find.
  • Things that AutoZone, Advance, etc. carry. (CarQuest & NAPA are OK, since they usually have a better selection of obscure things than AZ or Advance)
  • Any listing citing the FieroStore as a source, unless that's not readily obvious.
Last edited by The Dark Side of Will on Sat Apr 07, 2007 8:58 pm, edited 2 times in total.
Jinxmutt
Post by Jinxmutt »
crzyone
JDM Power FTW
Post by crzyone »
http://www.kinsler.com/
injector bungs (weld-in, epoxy-in, and threaded), extruded fuel rail material, injectors, tooling for cutting injector pockets, etc..
cactus bastard
Post by cactus bastard »
http://www.midwestcontrol.com/
Clevises, rod ends, turn buckles etc. Anything from suspension to throttle linkages.
http://www.aa-mfg.com/pdshop/shop/
All sorts of interesting brackets and mounts
http://www.bicknellracingproducts.com/
http://stockcarproducts.com/
http://www.speedwaymotors.com/
http://www.racecareng.com/RCE1/
General racing parts
Indy
Post by Indy »
http://www.rossmachineracing.com/
Intake fabrication, extrusions, fuel rails, bosses, tools and cutters. I HIGHLY recommend them.
Lots of flanges, piping & pre-cut parts for turbo projects:
http://www.roadraceengineering.com/hack ... rparts.htm
The full gamut of composite fab products, oriented toward home-building airplanes.
http://www.aircraftspruce.com/menus/cm/index.html
General composite supplies:
http://www.uscomposites.com/products.html
Various body, interior & trim clips:
http://autobodyclips.com/
Fiero A-pillar trim clips:
http://autobodyclips.com/index.php?Sear ... ctID=16865
SMC compatible resin for bodywork/repairs.
http://www.evercoat.com/productDetail.aspx?pID=16
Another source for Handi-Foam (1.75lb/cf)
http://www.grainger.com/Grainger/items/4KK28
Awesome prices on Handi-Foam, but $50 minimum order:
http://www.betterfoam.com/
METRIC (!!) steel tubing:
http://www.hoseandfittings.com/catalog/ ... etric.html
Constant tension hose clamps:
http://www.hoseandfittings.com/catalog/ ... Clamp.html
Series8217 wrote:Constant tension hose clamps:
I REALLY hate dealing with these when they've been on a car for 20 years...
A wide variety of high strength Metric fasteners, including 12.9 hex head cap screws:
http://www.lawsonproducts.com
Steven Snyder wrote:
GM makes a special version of Synchromesh that is designed for limited slip differentials. It's called Friction Modified Synchromesh. The part number is 12377916.
2.17 ID Coil over sleeves to work with Koni struts without modification:
http://www.a1racing.com/index.asp?PageA ... rodID=1734
and nut:
http://www.a1racing.com/index.asp?PageA ... rodID=1744
page 7, model 2817:
http://www.koni-na.com/pdfcatalogs/KONI ... atalog.pdf
Some assembly required
Edit: They have the internet on compyooters now.
http://www.koniracing.com/2817.cfm
