Parts & Materials Library / Hard to Find Parts
Re: Parts & Materials Library / Hard to Find Parts
Following up on "bung adjuster nut" from above:
https://midwestcontrol.com/shop/BAN-16-12-1
1"-12 LH OD threads, 3/4-16 RH ID threads
HOWEVER, when you do a search on the Midwest Control website, the results include only BANs with LH ID threads. Weird. I prefer the RH ID threads because it makes obtaining replacement rod ends easier.
https://midwestcontrol.com/shop/index.p ... earch=banl
https://midwestcontrol.com/shop/index.p ... 20adjuster
Also noticed that MidWest Control was mentioned on page 1:
cactus bastard wrote: Sat Apr 07, 2007 9:04 pm http://www.midwestcontrol.com/
Clevises, rod ends, turn buckles etc. Anything from suspension to throttle linkages.
http://www.aa-mfg.com/pdshop/shop/
All sorts of interesting brackets and mounts
Found this koni distributor in Australia that also manufactures weld on strut gland nut adapters for koni strut inserts as well as integrated sleeve and gland nut adapters.
Have a set of weld on adapters on order.
http://www.toperformance.com.au
http://www.toperformance.com.au/app/upl ... _Pages.pdf
http://www.fiero.com/forum/Forum2/HTML/143025.html#p1
Originally posted by fierofool:
There is a rubber insert that goes into the spoiler. Called Well Nut. The Au-Ve-Co number I have is 16248 and the size is M5 - 8 Range .035 - .232 in. You will need PanHead screws to fit into the countersink of the wing stand in order to prevent breaking the wingstand. I recommend brass or stainless screws and a little never seize on them in case future removal is needed.
Fastenal sells Well Nuts by various manufacturers. Grainger should also have them. I bought mine at an automotive paint and body supply but I had to wait for them to order them in. Fastenal had them on hand.
I also have a Well Nut number 8832. Range .38 - 3.96 mm. These are larger and I don't believe they're the ones I've used for the spoiler.
While crawling through and assembling the wiring on this LF3/LF4 I came across a blunt cut shield segment of the wiring diagram. The Fuel Pump Control Module PWM 12awg cables to the fuel pump puts out enough noise GM shields them due to an abundance of EM with a grounded shield wire back to the module.
You can't order the harness portion from GM without purchasing the entire body harness which is ridiculous in price both from GM or ebay.
ShowMeCables.com has an equivalent shielded wire offering sold by the foot.
https://www.showmecables.com/catalogsea ... Tray+Cable
Since this is for a non-motion setup, i.e. robotic arm etc... the more economical Tray Cable variety over the VFD type can be used
This is what I was looking at for shielded wire, it appears to be very high quality.
https://prowireusa.com/c-58-shielded-tefzel-cable.aspx
Tefzel = $$$
The Dark Side of Will wrote: Thu Dec 26, 2019 2:30 pm Tefzel = $$$
true, but its one of the only options I have found that is temperature rated, and oil resistant, and shielded.
while I'm not sure this fits the description of "hard to find", I will say they seem kinda difficult to find as a not garbage product.
This is a fuse panel from Blue sea systems, meant for marine applications. while I've used their products in the past with good results, I noticed the covers were usually pretty rattly, this one, and it's smaller four circuit companion are much tighter, and more compact(the real important part). Because they're built for marine environments, the components are corrosion resistant, more than fine for use on a car. I would highly recommend these, part number are 5045 for four circuit, and 5046 for eight circuit.
I'm planning on picking up one of their "safety hubs" for the wiring coming off of the battery in my car, as they provide a weather-tight connection point, with megafuses for power distribution. I'll post a review of it when it gets here.
Snazzy stuff for builders
Pioneer 500189
new 87-88 timing cover. I was genuinely surprised they make one.
Honest Don wrote: Wed May 27, 2020 1:26 pm Pioneer 500189
Oh, yeah... I found that back in early 2018 when the Storm Trooper broke its timing chain.
Be warned that there are TWO that look very similar except they're built for waterpumps turning opposite directions.
The Dark Side of Will wrote: Wed May 27, 2020 2:13 pm
I have one and fit is verified. :-)
Good wire harness wrapping/bundling tape.
Tesa 51036.
This fabric-based tape can be used in engine compartments, and is sticky, but not gummy. Available in 3/4" and 1" widths; the ideal width depends on the size of the bundle you're trying to wrap.
https://www.waytekwire.com/item/20923/T ... e-Harness/
https://www.waytekwire.com/item/20924/T ... sion-Wire/
I say this is good for wrapping/bundling wire harnesses.
Do not use Tesa 51036 for sealing wire splices, instead use adhesive-lined heat shrink tube.
For Y-splices, heat shrink tube cannot seal the gap between two adjacent wires. I apply Permatex 85121 liquid electrical tape to the area, and then shrink the tube while the liquid electrical tape is still wet.
Dorman cooling system bleeders that screw into 1/8" pipe locations:
https://www.rockauto.com/en/moreinfo.ph ... 08&jsn=499
CV axle parts, could be useful for custom axle builds, or just replacement parts for a stock axle shaft.
http://www.rockfordcv.com/CV_Component_Catalog.htm
Texense:
https://www.texense.com/en/
I was shopping for strain gauge amplifiers (work-related), and I noticed this Bosch LSU 4.9 wideband controller on their web shop (they use different URLs for the actual add-to-cart shops):
https://www.sens4pro.com/en/products/11 ... oller.html
I don't like how wideband oxygen sensors generally need a separate controller box, which you need to figure how to mount/package.
This product builds the controller into the connector, so you don't have to figure how to install the controller box.
Texense also has other instrumentation products; it may be worth looking though their offerings. At the top of the webpage, there's a currency selector to choose USD for the convenience of the Yanks.
Fuel tank bulkhead connector with a low enough profile to fit a fiero tank.
https://www.racetronix.biz/p/universal- ... y/bcws-001
ericjon262 wrote: Wed Jan 05, 2022 4:08 pm Fuel tank bulkhead connector with a low enough profile to fit a fiero tank.
oOoO0Oh...
And 14ga too... Nice!
While working on the Gran Damn, I noticed the battery tray is fairly flat, and appears that it could fit swaps nicely if needed, they're also plastic, so they shouldn't rust.
