Page 3 of 9
Posted: Tue Sep 23, 2008 3:25 pm
http://rubbercal.com/CI_Sheet.html
Cloth-inserted sheet rubber. This is good for making splash guards as well as air baffles/guides like those that direct air into the radiator.
It is not the same as the masticated rubber sheet that GM used for same purpose. That stuff is very hard to find in small quantities and isn't as strong or durable as this stuff.
Posted: Wed Sep 24, 2008 4:26 pm
by Indy
Stainless, mild steel, aluminum tubing/fab:
http://www.woolfaircraft.com/index.php
Good prices.
Posted: Mon Sep 29, 2008 4:55 pm
by lucky
I put a link to PST earlier in this thread, but here's a link to their site with a search query for "Fiero" built in. Complete front steering rebuild kits, polygraphite suspension bushings, bigger sway bars, prebent brakeline kits, etc.
http://www.p-s-t.com/search.aspx?Search ... &Submit=GO
Posted: Tue Sep 30, 2008 2:39 pm
by Starlite528
lucky80 wrote:I put a link to PST earlier in this thread, but here's a link to their site with a search query for "Fiero" built in. Complete front steering rebuild kits, polygraphite suspension bushings, bigger sway bars, prebent brakeline kits, etc.
It just sticks me in the front page as if I had never typed it. Cool, because I want to fix my suspension anyways!
Posted: Thu Oct 09, 2008 6:42 pm
by lucky
#'s for JCW's recycled fiber automotive insulation.
YH268584 4'x6'
YH268585 4'x24'
YH268586 4'x48'
ADJUSTABLE TIE ROD ADAPTER STUDS
Posted: Sat Nov 15, 2008 2:12 pm
by Forever-Fiero
This little adjustable tie rod adapter stud allows you to use 5/8" rod ends instead of OEM tie rods. It also allows you to adjust steering geometry.
Made of 4140 chrome moly and zinc coated. Choose from GM or Pinto. IMCA approved.
http://www.speedwaymotors.com/Adjustabl ... ,3333.html
[Edit: Speedway website changed; link updated]
Posted: Sat Nov 29, 2008 6:08 pm
by Xanth
Possible alternative to the OEM Fastback trunk gasket:
http://www.jcwhitney.com/autoparts/Item ... 0000163412
Gasket mounts at a right angle, putting it in the correct orientation for use on the fastback trunk.
Posted: Sat Jan 03, 2009 7:47 pm
by lucky
Motormite #03411 exhaust manifold stud kit, listed for the ford 4.6, is the correct thread for the 60deg V6 (m8x1.25). Only problem is it's only 10 studs and 10 nuts.......
Posted: Sat Jan 03, 2009 9:33 pm
lucky80 wrote:Motormite #03411 exhaust manifold stud kit, listed for the ford 4.6, is the correct thread for the 60deg V6 (m8x1.25). Only problem is it's only 10 studs and 10 nuts.......
Most every exhaust manifold stud kit nowadays will have the correct dimensions. You can also order the kit from Rodney, and it's pretty cheap too. Order 2 extra to replace the slave cylinder studs as well.
Posted: Sun Jan 04, 2009 1:54 pm
by lucky
Ordered from Rodney and on the shelf at your local parts store are completely different on a weekend night when you're trying to get a car back together to get to work the next day.
Of the 6 stud kits on the shelf, this was the only METRIC one.
eBay store "Tom's Pony Parts and Trains" has a Fiero specific stud kit cheaper than Rodney (lots of other random Fiero fasteners also).
Laughing my ass off the board changes your name to Retard.
Thanks for the apple, there was mold all over the inside of the box, I owe you one.......
Posted: Sun Jan 04, 2009 1:57 pm
I know how that goes!
Every common GM one will be metric, and the same threads.
Yuck, I didn't think about that. Disgusting, sorry. I guess next time I'll toss in something not degradable.
Posted: Tue Jan 06, 2009 11:49 pm
by lucky
retard wrote:Every common GM one will be metric, and the same threads.
This was the only non-Gm, AND the only metric one.
Re: Parts & Materials Library / Hard to Find Parts
Posted: Fri Jan 30, 2009 9:52 am
http://www.cliphouse.com/
LOTS of miscellaneous minutiae like body fasteners, electrical supplies, connectors, etc.
Posted: Mon Feb 02, 2009 12:53 pm
by lucky
http://www.emachineshop.com/
Download their free CAD program, design your custom part, submit it for an instant price quote; freakin awesome.
Posted: Fri Feb 13, 2009 12:27 pm
by Forever-Fiero
With all the custom intakes being built on here I thought thees would help out. The First is a great place to fined ITB parts and the Second is a total build from scratch manifold supplier with good prices.
http://www.twminduction.com/
http://www.rossmachineracing.com/index.htm
Posted: Fri Feb 13, 2009 12:35 pm
by Forever-Fiero
Great place. They offer quality Pipe, Tubing, and Mandrel Bent Elbows. Custom order any size any bend any radius in stainless, mild, aluminum and galvanized.
http://www.velocityair.cc/welcome.htm
Posted: Fri Feb 13, 2009 8:00 pm
by Forever-Fiero
Widening and Narrowing Wheels
Weldcraft Wheels is your source for expert repairs and fabrication on your custom or factory wheels. They specialize in wheel modification(aluminum or steel). They widen wheels and narrow wheels. They also move your centers when possible.
http://www.weldcraftwheels.com/
Posted: Sat Feb 14, 2009 9:41 am
Forever-Fiero wrote:With all the custom intakes being built on here I thought thees would help out. The First is a great place to fined ITB parts and the Second is a total build from scratch manifold supplier with good prices.
These are who made my ITBs. They are
really expensive, but the parts are absolutely top notch.
Posted: Tue Mar 17, 2009 6:55 am
Posted: Fri Apr 03, 2009 6:56 am
p8ntman442 wrote:check out
http://sealsit.com/firewall.asp for some great pass through rubber seals that are fire retardant. You can even get 2 peice units so you dont have to remove the lines, and put them back through. $15-20 each.
