Water/Air Intercooler resevoir
Just trying to figure out what to use for the fill. Any ideas?
My intercooler has 3/4 barbs, the front exchanger has 7/8 barbs, my pump has 3/4".
I was trying to figure out what to use with a cap and where to put it. I'd like to hide it somewhere or maybe put it where the battery was (WCF box up front). This won't be a pressurized sytem, right? It won't get very hot. Do I even need an overflow or even a cap? Maybe just fill the hoses at the highest point? Not sure if I could get the system full that way.
Yeah, stock NSX's use a fabbed aluminum washer fluid container.The Dark Side of Will wrote:I helped a friend design a W/A setup for his turbo MKIII MR2. He used a front exchanger from a Syclone, a PWR barrel IC, and some kind of fabbed aluminum washer bottle for an NSX or something weird.
Use some kind of a tank. That way you can drop in ice if you want. :thumbleft:
I went through about 20 junkyards Saturday and didn't find an NSX (ok, I really didn't).
I do have a couple of buddies with NSXs, but I don't think they will give me their tanks.
Now I am thinking of just using an overflow bottle with a couple of 3/4" barbs bolted in it. Any reason that wouldn't work?
