water temp sensor L67
dgzfiero
Live from Ard's Cricket Ranch
Post by dgzfiero »
Does anyone know where the water temp sensor is on a L67? 2000 SSEi motor if there is a difference. I've looked all over the top of the motor that I can see. It is showing P00118 coolant temp circuit high input on a code reader.
Should be near the thermostat.
Maybe in a cylinder head.
Jinxmutt
Post by Jinxmutt »
Its under the T-stat. It threads in 'upwards'. It comes really close to the crossover and usually has a silver heatshiled tube over it (from the factory).
Look near the 'arm' of the engine stand.
dgzfiero
Post by dgzfiero »
OK I never looked under it there. Thanks
