ok i just replaced my rear calipers,pads,rotors and my front pads and rotors
i had no problem compressing the front calipers. but when i hit the brakes it pulls really hard to the left!! this means it needs a new caliper right?
brake issues
Could be a couple of things.
Take the right caliper off and make sure the slide-pins still move, that the brake pads aren't looking wierd (i.e., covered in brake fluid) and that the piston comes out when you push the brake pedal.
If the piston is jammed in the bore, you can either rebuild the brake caliper, or replace it.
Could also be something as silly as a kinked brake line, or something plugging it.
