Video: Viper Maxes out the Dyno
I am sure Steve Kelleys Green booger could max out a dyno on the spray as well.
http://www.6speedonline.com/videos/ryansTT.wmv
Unlike brake dynos which directly measure torque and calculate horsepower, inertia dynos measure power and calculate torque*. Therefore the 1207 you calculated isn't more accurate than the 1200 that the dyno maxes out at.crzyone wrote:I just did a hp calculation and the peak hp I could find was 1207hp @ redline. Pretty damn impressive. I was just using his torque numbers and rpm.
(*more accurately, inertia dynos measure the acceleration of a known mass and use this information to calculate power and then torque )
I saw that, too. I think that it's not actually measuring torque. Because of the linear relationship between hp and torque, if hp stays constant then torque will decline linearly as rpm increases. In this case that linear decline of torque blends in with the torque curve up to that point so it's hard to see.crzyone wrote:I just saw how it kept measuring torque after the hp had already maxed out.
Ahhhh yes! Some nits to pick!Doug Chase wrote:Unlike brake dynos which directly measure torque and calculate horsepower, inertia dynos measure power and calculate torque*. Therefore the 1207 you calculated isn't more accurate than the 1200 that the dyno maxes out at.
Inertia dynos measure acceleration of a known mass... that sounds like a force to me. Since it's a force applied at a known radius, it's a torque.
They measure the angular acceleration of an object with a known moment of inertia. Torque is the rate of change of angular momentum, just as force is the rate of change of linear momentum.
Fair enough. I guess it would have been more accurate to say that we're not directly measuring force and instead we're measuring time and drum speed (or position, I don't know the intimate details of Dynojets).The Dark Side of Will wrote:Ahhhh yes! Some nits to pick!
With this information we can calculate both hp and torque. Since we have to get out the calculator then it doesn't matter which one we solve for first. My point was simply that the torque line on the graph doesn't contain any more information than the hp line.
:blah5:
YUP!The Dark Side of Will wrote:
I've heard of things like airing down the tires, strapping the shit out of it, then reinflating the tires and taking a pull to heat them up then being able to get a good pull subsequently.
What you will have a lot of times is people just throwing the car up on there and strapping it down to where it "feels" good and tight. Sometimes in high hp cars its not.
