Opinions on twins VS big single?
Posted: Sun Aug 19, 2007 3:43 pm
In general, what are your opinions on smaller twin turbos vs a large single turbo on a V6? I'm looking for some pros and cons of each setup.
Being that i'm used to the supercharger, I was thinking that a set of small internally gated turbos would give me somewhat similar drivability as I'm used to, with more ability to flow efficiently on the top end. I would think that a turbo on each bank should put me around 425 to the wheels with a fairly nice power curve.
On the other hand, I could run a big single and lose the low end as i'd have a bit more spool time. I should be able to make much more top end power, however. Also, running through the gears, the spool should really be unnoticeable because the shifts will keep me above what the spool rpm would be anyways. I'd probably only notice at low rpm where I would have to downshift where as I may be able to hold the gear with the twins.
I'm just in the early stages of brain storming, but i'm tossing around the idea of two turbos on the 3800. I'm going to be using a different upper intake, either something fully custom, or a modified holden intake. I'm also going to be switching to a stattama turbo cam since they seem to be fairly common in the marketplace.
