88 rear sway bar bushings
jelly2m81
Post by jelly2m81 »
Anyone know of a source for the 88 rear inner sway bar bushings?
Thanks!
stock rubber ones?
jelly2m81
Post by jelly2m81 »
Shaun41178(2) wrote:stock rubber ones?
rubber or poly, it don't matter to me.
summit has poly. measure the bar. its either 22mm or 23mm. i forget.
Steve25
Post by Steve25 »
Same solution for the front? And a follow on question. What is the factory front sway bar diameter for an 88 GT? 1.1", 28 mm?
Steve AT 88GTP DOT com
jelly2m81
Post by jelly2m81 »
Oh, I forgot to mention this. I made a set of rear sway bar bushings, I used a set of Moog thermoplastic rubber sway bar bushings from a late model Cavalier with a 22 mm bar.
Not a direct replacement, but 5 minutes at the bench grinder was all it took to grind down the center to fit in the stock bracket, and trim a little off the bottom. The Cavalier bushing is a bit beefier, but it is large enough to shape it so that it has shoulders on either end to hold it in place like the stock bushings.
I'll try and remember to take the camera to the shop and get a pic.
Steve25 wrote:Same solution for the front? And a follow on question. What is the factory front sway bar diameter for an 88 GT? 1.1", 28 mm?
Yes, 28mm is the size of the front swaybar for all 88 Fieros.
