Does anyone know if DSM injectors will physically fit on the 2.8's setup? I'm running a MS-II so the impedance and whatnot won't be an issue.
Thanks!
DSM injectors?
Shaun41178(2) wrote:I don't think they are low impedence so they can probably be used. I however am not sure if its possible as I don't think the tips are the same size as like a delphi injector. They might not fit snug in the injector bung.
ARe the injector clips even the same?
the clips appear to be the same but they use a different style o-ring on the bottom of the injector. changing rings might be possible though.
DSM injectors are low-impedance, but the Megasquirt-II will run them with merely a parameter setting.
The bottom part of the injector should work with a fiero o-ring. But I don't think the top will work. I am using Fiero top injector o-rings in my GSX with a holley fuel rail. But they will not work with the factory 450cc injectors, the groove for the o-ring isn't wide enough to run the larger diameter Fiero one. They could probably be made to work, with a little filing or whatever of the top plastic groove. I am running FIC 1150cc injectors with my eclipse, and they use two smaller diameter upper o-rings, so one larger fiero style will work. Stock only uses one, so they don't fit. Good luck though, I may have to try it, cause I'll need more than my 30lb injectors for my turbo 3400. I just need to get a 3000gt vr4 resistor pack, unless my Haltech can work with either, which i think it can.
Justin W
Justin W
1990 Eclipse GSX-parted out
2004 Honda TRX450R #33W mx
2001 GMC Sierra C3 AWD
EMX5636 wrote:The bottom part of the injector should work with a fiero o-ring. But I don't think the top will work. I am using Fiero top injector o-rings in my GSX with a holley fuel rail. But they will not work with the factory 450cc injectors, the groove for the o-ring isn't wide enough to run the larger diameter Fiero one. They could probably be made to work, with a little filing or whatever of the top plastic groove. I am running FIC 1150cc injectors with my eclipse, and they use two smaller diameter upper o-rings, so one larger fiero style will work. Stock only uses one, so they don't fit. Good luck though, I may have to try it, cause I'll need more than my 30lb injectors for my turbo 3400. I just need to get a 3000gt vr4 resistor pack, unless my Haltech can work with either, which i think it can.
Justin W
thanks, good to know!
