Toe in or out?
Toe in or out?
According to this Fiero book I got, for autocross it calls for a 0-1º toe out on the front. I thought all vehicles had a toe in on the front suspension. Is there anything bad about running a toe out on the front and daily driving? I would think it would wear the tie rods out faster since it is pulling on the inners instead of pushing on them when you are driving.
I am looking for more of an autocross allignment, but also one I can drive daily, in rain and sun, and some snow. Anybody have some experience on what works and what doesnt?
Don't talk about things you don't know about.FormulaGT wrote:You will be all over the road, fighting to keep the car straight. Not worth it.
Toe out is NOT bad.
You'll notice a difference in straight line stability vs. toe in, but you won't be fighting to make the car go straight.
You can NOT retain ultimate stability AND have maneuverability at the same time. The trades are mutually exclusive.
Do you know what your talking about? :scratch: lolThe Dark Side of Will wrote:Don't talk about things you don't know about.FormulaGT wrote:You will be all over the road, fighting to keep the car straight. Not worth it.
Toe out is NOT bad.
I have set toe out personally on my car, and it drives like shit. It is no where NEAR a stable as toe-in, and you WILL be fighting the wheel. It is a PITA and it is not worth it, I speak from experience.
True, but when you have toe-out, that car wants to wander.Series8217 wrote:Not true. Caster will keep the car running straight.FormulaGT wrote:Yes, toe out is good for AutoX, but not for the street.
I am just speaking from experience here. I have a 2" lowered suspension with stiffer springs and full poly. My cars reaction to alterations may be affected greater, than say a stock setup.
MY experience is with my Northstar car, which has UHMW suspension bushings, rod end sway bar links and Koni shocks, with stock springs, bar and ride height.FormulaGT wrote:Do you know what your talking about? :scratch: lolThe Dark Side of Will wrote:Don't talk about things you don't know about.FormulaGT wrote:You will be all over the road, fighting to keep the car straight. Not worth it.
Toe out is NOT bad.
Toe out in a reasonable amount is NOT a problem.
How much toe out did you crank into your setup? It sounds like you either used WAY too much or are having some issues with your lowered geometry.
