Switching to hydrogen....
A number of these threads popped up on OE recently, and I have given some thought to converting the grand prix to alternative fuel (homebrew ethanol or H2 or propane or something..... mainly because I don't care if it blows up, in fact I want it to.) But here's my idea.....
First, I thought the ideal solution would be to generate hydrogen at home (using the grid), compressing it and storing it in metal hydride tanks (in vehicle). This would allow higher densities than liquified or pressurized tanks, while still being "safe" with respect to punctures and crashes causing leaks and explosions.
However, metal hydride tanks are expensive, on the order of $8000+ for 4 tanks that would get a reasonable amount of mileage. Second, hydrogen generation at home would have to be purified before and after compression to eliminate oxygen and other contaminants, which adds to the complexity and cost.
Then I thought about ethanol, and ran the math, and basically it boils down to homebrew ethanol not being cost effective unless you have unlimited access to trees to distill the mix, and/or free sugar.
Then the conspiracy nuts gave me an idea. They claim that running an electrolysis cell off your alternator will give you 1000 mpg. Obviously not true, but water is a good source of hydrogen. So, what if you were to generate the hydrogen in-car?
A number of sources say that a gallon of gasoline has about 40 kwh worth of energy. That's a bigass battery. But, think about this - most driving is city driving, and <20 miles. If you can fit a 40kwh battery in there, you could recharge your battery after every drive, and never have to fill up again. I'm sure with careful searching, a lithium or nimh battery pack could be built for a reasonable amount of coin. Add an electrolysis cell, a high rate SMPS charger and PWM controller and you've got a hydrogen vehicle. FWIW, costco has a 1kwh deep cycle battery for $50 (not including fees) and is probably about 60# (teh suck).
Using a 90% conversion efficiency, I think it works out to about $4/gal "equivalent". They say we'll be above that by the end of the summer, so the time to start building is now. Fit a solar charger, and you're ahead of the game.
hydrogen has a huge range of flammability, and some other interesting properties:
http://www.fisita.com/students/congress ... s/sc06.pdf
Thoughts/comments/ideas on where to steal a battery?
We did a homebrew electrolysis setup in my freshman chem class. It
worked beautifully and was very simple, but was a really slow process, and we were using a 100 amp battery charger.
Unless you're gonna run something like a 200amp alt with 0/1 cable to your trunk I don't think it's viable as a homebuilt alternative fuel source.
If you're scheming this up thinking you're going to save a buck, you're already way, way off track.
40 kwh battery for a reasonable amount of coin that doesn't weigh a ton? How many thousand bucks do you want to spend on a pack? 90% conversion efficiency? Solar charger? Man, you've been reading to many conspiracy theories. It'd be a hell of a lot less work and more fun to ride your bike to work. Hell, ride a motorcycle...burn 50% or less fuel, go faster, and have way more fun than you were in your car. That is, if you're man enough. Seriously, it's a hell of a lot easier to reduce consumption by changing your driving habits/style.
Bryce
Bryce
I'd agree that you best bet is to get a bike (motorized or not). If it makes you feel any better, I just filled up this past weekend at $4.33 a gallon. I get around 16 mpg in the V and it's like 16 miles to work one way. So just to get there and back I'm spending $9 a day. :cussing:
Fiero Build Thread here:
Why not just forget about a fuel at all and built a completely electric car? If you are using it for just around town driving, charging overnight would be ample time.
Hydrogen isn't worth anything unless its in a fuel cell, burning it isn't worth the trouble when ethanol is much easier to make, come by or steal.
1988 Pontiac Fiero
Or just crawl under people's cars, cut the fuel lines and have gas for free...
Hydrogen is a grossly inefficient means of energy transport. What did you add in for the energy costs of compressing it?
Water is everywhere because it's a stable molecule. Liberating hydrogen from it takes a good bit of energy.
Buy a TDI VW and run it on cooking oil.
Get another Fiero and swap it over to DI Ecotec power. The Northstar is a great engine, but not for gas mileage.
A carbon neutral chemical energy transport technology would probably be fine. Ethanol is essentially solar energy in a chemical transport medium.
It would be interesting to see what we could do if we ran all of our trash through thermal depolymerization plants to make light crude. Certainly wouldn't solve any supply issues, but might make a dent.
It's gradually becoming more economical to pursue oil reserves like oil shale that companies weren't even dreaming of going after 20 or 30 years ago.
The ultimate solution (nuclear fusion) is going to have to transcend the current ideas of renewable/non-renewable. It will be essentially limitless. We're 25 years from practical fusion. We've been 25 years from practical fusion for the last 50 years.
I bet a typical family could make 4 gallons of oil a week if they did it. I don't understand why they don't. Trash is free. All they need is heat to turn it into black gold. Imagine how much they would save in terms of landfill costs. Waste would probably be reduced 100x and what's left would probably be metal scraps.The Dark Side of Will wrote:A carbon neutral chemical energy transport technology would probably be fine. Ethanol is essentially solar energy in a chemical transport medium.
ITER is coming online in 2016? The polywell fusor is promising and I think could be operational soon given enough funding for research.
I work about 44.5 miles away, almost 90 miles a day for me. Even with the 2.5 on $4.10 piss water I'm spending more than that a day for fuel. I have half the mind to get a CRX, gut it, and put in the smallest, most efficient engine Honda made. Or get the CVCC carbed one.Unsafe At Any Speed wrote:I'd agree that you best bet is to get a bike (motorized or not). If it makes you feel any better, I just filled up this past weekend at $4.33 a gallon. I get around 16 mpg in the V and it's like 16 miles to work one way. So just to get there and back I'm spending $9 a day. :cussing:
There is a late 80s prelude on craigslist near me for $300, can you say gutted on 60psi steelies?
Everyone goes well "its not better than gas so its not worth it" petroleum is very good at what we use it for, thats probably why every car was built to run on it, unfortunately we need to take some set-backs and try something else.
(I say this as I work on a 93 octane 3800 swap... hypocrite)
If ethanol were allowed to emerge from underneath gasoline as its own commodity, it might be able to undercut the gasoline price enough that the cost per mile is less even with the mileage hit. At that point ethanol will be viable.
But in an effort to build ethanol production, Congress mandated that all gasoline contain 10% ethanol. Because of the volume of gasoline produced, that requirement dominates the ethanol market and effectively ties the price of ethanol to the price of gasoline. Once that mistake is rectified, ethanol might actually be a good choice.
I've been thinkin about this... think it would be feasible to use a homebrew electrolysis setup in-car with a vacuum line and check valve rigged to suck the H2 generated directly into the intake air? You'd still have to have your gas or ethanol or whatever in the tank, but theoretically couldn't you taper off the gas? Or would it just function more like NO2 as a power adder?
You'll never make enough H2/O2 to fuel even the smallest engine. Plus where's the energy coming from? Electrolysis sucks for efficiency. It also sucks to make work correctly due to nasty issues with electrode corrosion. I once made enough hydrogen/oxygen mix to fuel a tiny torch for a 10 or 15 seconds - after 15 minutes of pumping 12V though several square feet of electrode area, separated by a couple thicknesses of paper towel (they were oxidized to uselessness afterwards)...Try hooking your car battery charger to two electrodes of reasonable size, and dropping them into water. If you're really impatient, add something to increase the conductivity of the water. You'll probably give up on the idea. With tap water, you need massive amounts of electrode surface area.lucky80 wrote:I've been thinkin about this... think it would be feasible to use a homebrew electrolysis setup in-car with a vacuum line and check valve rigged to suck the H2 generated directly into the intake air? You'd still have to have your gas or ethanol or whatever in the tank, but theoretically couldn't you taper off the gas? Or would it just function more like NO2 as a power adder?
With noble metal plated electrodes, you could possibly sandwitch a porous material and the two electrodes, and roll it up to make a reasonably sized cell, and feed it water with like, sodium hydroxide or something to bring the conductivity waaaay up so you can flow enough current to make a decent amount of output. It'll output mixed O2/H2 gas at a stoich mix.
