So many problems to fix on this car. Martin is ready to hunt down and kill everyone at Subracing for their shoddy work.
Where should I start... Missing starter bolt, missing transmission to engine bolts, missing front driveshaft bolts, broken shifter fork (which required dropping the transmission to fix), rear turbo oil feed line not installed properly, vaccuum lines not plugged on bottom of plenum, missing subframe bolt, blah blah blah... This build has been delayed quite a bit with these problems.
On the plus side, oil lines are on and motor has been primed. Makes good oil pressure. Guages are done. Car is basically ready to fire up except for some reason the hand held commander for the ECU doesn't want to work. They are waiting for everything to check out before firing it up for the first time. Should happen tonight or tomorrow if they can narrow down the problem.
Anyways, here are some pics
Oil cooler installed (those massive scoops everywhere are actually functional!)
25mm wheel spacers installed, good fitment on the front, might need more on the rear
I need a lift in my garage...
Finished engine bay
All lit up. Can choose 7 different colors
Found a pipe cleaner in the heater hose!!! Good work subracing....
Said they found a hairline crack on the weld. Not sure what to do abou that now. Can't see it in this pic
Anyways, in a few days I should be able to update again if it runs or not. Martin is doing excellent work fixing all of Subracing's mistakes.
