I never claimed to be a welder (aka Don's Turbo Build)
Re: I never claimed to be a welder (aka Don's Turbo Build)
he isn't using it, he pulled it for his 3800 swap.
found four potential candidates at the local u-pull-it. I'm going to try and round up some help to drag one home on Saturday
Is anybody interested in my crossover & downpipe/muffler? other than relocating the coil, they'll go right on a 2.8/th125 car.
If not, I'm just going to cut them up and fit them to the new motor/manifolds as needed.
well, its been awhile so I figured I'd give an update for whoever's still interested..
Here's the motor I picked up awhile back:
The teardown begins!
The Napa oil filter sold me when I went and looked at it :)
The cylinders actually look pretty good in person. I think I can get away with only a quick hone and some fresh rings:
Looking the heads over:
Aw dammit, looks like I'll be giving Smithberg a call.....
On the plus side of things, here's a comparison between the old and new intakes:
CincinnatiFiero
Post by CincinnatiFiero »
Your turbo should love that intake. Really want to 3400 my 88 now haha.
Yay, Parts!
Emc209i
Post by Emc209i »
Yay.
vortecfiero
Post by vortecfiero »
looking good
Id recommend supporting the turbo as that type of exhaust tubing will crack from the weight and vibration.
KurtAKX
Post by KurtAKX »
[quote="Honest Don"]Yay, Parts!
Looks like someone bought the expensive steel backed rubber intake manifold gaskets!!!
(unless they've become the standard since the last time I did that job)
I put a set in at 79k on the wife-mobile Aztek, at 146k now, haven't even had to top off the reservoir.
vortecfiero wrote:looking good
I have a support going from the turbo flange to the top of the transmission. Seems to work out pretty good
Dropped the heads off yesterday. Here's a few progress pics:
BOSSMAN wrote:Bringing these heads back to life for Don's project.
Before
After
Before
After
BOSSMAN wrote:Valve Job Before
Valve Job After - Custom Cutters for Turbo App.
Back Cut on Intake Valves (Valve Comparison)
BOSSMAN wrote:Almost done Don. Heads are now surfaced .010 and was able to remove the fittings in the heads (threaded fittings FYI). I plan to assemble them tonight and will have final pics then. This project is going quicker than I planned for. :thumb:
BOSSMAN wrote:All done, turned out real nice.
coool. its coming along.
Shaun41178(2) wrote:coool. its coming along.
slowly but surely. I'm finally back up to a 5 day workweek, so I actually have cash to work on it again
Emc209i
Post by Emc209i »
Bea u t i f ul. :good:
