4speed Vs. 3500
Re: 4speed Vs. 3500
The TH125 axles have smaller diameter shafts and CV joints than the manual transmission axles.
Both manual transmission axles use mail splines at the transmission end. I believe the TH125 axle uses female splines on the driver's side.
Re: 4speed Vs. 3500
Yep.The Dark Side of Will wrote:I believe the TH125 axle uses female splines on the driver's side.
Re: 4speed Vs. 3500
Learn something everyday.
Re: 4speed Vs. 3500
so in other words, I need to source a driver side axle still.
Re: 4speed Vs. 3500
Unless you plan to use a newer series automatic transmission... yes.
Re: 4speed Vs. 3500
Whats the best source for an axle? any other cars use the same axles? are there any cheap upgrades I can do?
Thanks-
Eric J.
Thanks-
Eric J.
Re: 4speed Vs. 3500
Keep checking the Old Europe Mall, I just saw some M/T axles on there yesterday. To use the 4-speed manual, just get the axles from any M/T Fiero.
Re: 4speed Vs. 3500
I'm going to get a reconditioned set from rock auto. any downside to this?
Re: 4speed Vs. 3500
Aftermarket shafts are made of modeling clay, or maybe at best a high grade of solder. If you're running significant horsepower and launching the car hard, you'll need factory shafts.
Matt Hawkins went through several sets of reman axles before he tossed a set of junkyard factory axles into his car and stopped having problems.
Re: 4speed Vs. 3500
do you think I'd have problems with a stock 3500 breaking them? that's the most I'd be throwing at them for a long while.
Re: 4speed Vs. 3500
Probably not. Still, you might as well take a 30mm axle nut to the yard and find a set of used axles.
Re: 4speed Vs. 3500
fieros are non existent in the yards in northwest florida, any other cars have the same axles?
Re: 4speed Vs. 3500
No, I'm not aware of any other vehicle. If you cant find them down there, source them from anyone online. I have a couple of extra pair, but I'm keeping them because I'm probably going to need a few backup sets.
Re: 4speed Vs. 3500
well, if any of you have a set, PM me a price! otherwise, old europe it is.
Re: 4speed Vs. 3500
I broke down and sent you a PM.
