dhen wrote:And with respect to all, these cars are 25+ years old...
That's exactly how I feel. Enjoy the car for what it is.
Series8217 has experience setting up paddle shifters. You'd want the 4T65e-HD that came with the 3800. Of course that would be an expensive novelty that really isn't needed considering the PCM is completely tunable for shifting the automatic. So it would be a sport option. At that point I'd just install a stick - because I wouldn't be drag racing.
I don't think you'll ever see quick shifts out of a paddle shifted 4 speed automatic. The heart of those transmissions is still the Simpson gearset. Transmissions based on that gearset just take time to shift because they have lengthy hydraulic passages compared to GM's modern 6 speed clutch-to-clutch automatics.
The Dark Side of Will wrote:I don't think you'll ever see quick shifts out of a paddle shifted 4 speed automatic. The heart of those transmissions is still the Simpson gearset. Transmissions based on that gearset just take time to shift because they have lengthy hydraulic passages compared to GM's modern 6 speed clutch-to-clutch automatics.
This is correct.
The paddleshifter setup I installed on a 4T80E was more gimmicky than anything. It shifted very slowly (on the order of seconds).
This is correct.
I'd like to see more long term testing as well as more people using the f35 behind 3800s for durability. I know that the 65 is robust and reliable and can shift quickly no paddle shift required.
I guess using the thelin mounts is the best way to go than with the f35?
Shaun41178(2) wrote: I know that the 65 is robust and reliable and can shift quickly no paddle shift required.
It shifts quickly in that it can be programmed to shift firmly and at a given RPM during automatic operation. However, the hydraulic operations start happening 1-2 seconds before the transmission actually shifts gear. The indicated gear change is the tail end of the shifting operation.
