I created a spacer for the UCA to raise it an inch and move the mounting point rearward .75", to make it easier to get the 6-6.5* caster I've read is optimal with a small amount of static negative camber. While the dynamic camber gain looks good, it has raised a couple of new problems.
The hub is tilted back with the added caster, which puts the tie rod at about a 6* angle, which has created a lot of bump steer.
Anybody have an idea how much bumpsteer is acceptable? By lowering the steering arm .4 inches (according to the suspension program) I can get the bumpsteer down to around .5* (the program lists it as degrees).
One way to do that would be to reduce the anti-dive by raising the rear pivot point, which has the effect of lowering the steering arm.
What would be the effect of raising the rear pivot point .5"? That would still leave the tie rod at a 4.5* angle, which seems high, but it doesn't seem to affect the bump steer.
Another way to lower the steering arm is to heat it and bend it down. I think that can be done without weakening the arm too much.
![Image](http://i152.photobucket.com/albums/s177/bse53/802c13d2-d75a-4e45-b9c5-4f790a84fe9f_zps5acba392.jpg)
