mrsleeve91's DOHC build thread
- mrsleeve91
Re: mrsleeve91's DOHC build thread
Well I just found / installed a set of 60lb inj.s that have a very similar spray patter to the stockers.
Now I just need to put the intake on and powder coat the new t-housing, and put on the exhaust and I should be ready for take two!
Wish me luck! lol
Wish me luck! lol
86 Fiero GT, LQ1 turbo HX55, getrag
94 Ranger 2.3 lima turbo, t5, lowered 6/7.5 (DD)
Re:
Gonna need a slightly larger injector for 800. Just read over this thread again... and of course it goes without saying, but you've done a fantastic job. Can't wait for video.mrsleeve91 wrote:Well im expecting 600hp+ but 800 doesnt seem impossible. Iknow Ineed
to step up the inj. just been seeing what it can do..
Sounds like this should be entertaining!
Bump for dyno charts!
does someone know something the rest don't? I figured this was dead and was actually thinking about this build yesterday
- mrsleeve91
Numbers?
Bump for
Emc209i wrote:Numbers?
Mrsleeve91 was wondering if u could pm me about the headers I talked to u about on 60degree
DittoGambler87 wrote:Mrsleeve91 was wondering if u could pm me about the headers I talked to u about on 60degree
from email correspondence.
410hp 378lb on 8.7 psi and my crappy 42lb inj.
I just received my 65lb bosh inj. And a sheet metal short runner intake is in the works.
I'm planning on hitting the dyno again this summer with my new upgrades and 18psi.
Relay to him via email:
"Turn the boost up to 15 lbs and see if the engine lasts."
Dude you have a hard-on for railing on the LQ1... however, even Matt Hawkins turbo'd properly tuned LQ1 eventually suffered a disintegrating timing chain tensioner after 60K and FerrariFan's GT30 LQ1 wasted a con rod bearing after boosting to 17psi without retuning..Emc209i wrote:Relay to him via email:
Given MrSleeves all out build I wonder where the next failure point will be...
<edit = tensioner not timing chain failed>
You see a trend, eh?
