mrsleeve91's DOHC build thread
mrsleeve91
Re: mrsleeve91's DOHC build thread
Post by mrsleeve91 »
Well I just found / installed a set of 60lb inj.s that have a very similar spray patter to the stockers. :-D
Now I just need to put the intake on and powder coat the new t-housing, and put on the exhaust and I should be ready for take two!
Wish me luck! lol
86 Fiero GT, LQ1 turbo HX55, getrag
94 Ranger 2.3 lima turbo, t5, lowered 6/7.5 (DD)
Emc209i
Re:
Post by Emc209i »
mrsleeve91 wrote:Well im expecting 600hp+ but 800 doesnt seem impossible. Iknow Ineed
to step up the inj. just been seeing what it can do..
Gonna need a slightly larger injector for 800. Just read over this thread again... and of course it goes without saying, but you've done a fantastic job. Can't wait for video.
fieromadman
Post by fieromadman »
Sounds like this should be entertaining!
Bump for dyno charts!
does someone know something the rest don't? I figured this was dead and was actually thinking about this build yesterday
mrsleeve91
It lives.
Emc209i
Post by Emc209i »
Numbers?
Bump for
Emc209i wrote:Numbers?
Gambler87
Post by Gambler87 »
Mrsleeve91 was wondering if u could pm me about the headers I talked to u about on 60degree
Gambler87 wrote:Mrsleeve91 was wondering if u could pm me about the headers I talked to u about on 60degree
Ditto
from email correspondence.
410hp 378lb on 8.7 psi and my crappy 42lb inj.
I just received my 65lb bosh inj. And a sheet metal short runner intake is in the works.
I'm planning on hitting the dyno again this summer with my new upgrades and 18psi.
Emc209i
Post by Emc209i »
Relay to him via email:
"Turn the boost up to 15 lbs and see if the engine lasts."
Emc209i wrote:Relay to him via email:
Dude you have a hard-on for railing on the LQ1... however, even Matt Hawkins turbo'd properly tuned LQ1 eventually suffered a disintegrating timing chain tensioner after 60K and FerrariFan's GT30 LQ1 wasted a con rod bearing after boosting to 17psi without retuning..
Given MrSleeves all out build I wonder where the next failure point will be...
<edit = tensioner not timing chain failed>
Emc209i
Post by Emc209i »
You see a trend, eh?
