The CNC program development and machine setup are fully half the cost of the quote, so if I could run more parts, the price will come down significantly. A run of 20 (3 additional sets) should come down to around $70 each; a run of 52 parts (11 additional sets) should be around $58-$60
The shells are, of course, only one piece of the puzzle. Also required are spacers (bespoke; will get a price for those), Aurora CM-10 spherical bearings, ID snap rings and shaft seals.
The shells fit ALL years of Fiero front lower control arms.
They WELD in place. I have not yet developed a press-in model.
EDIT: To install the shells to your control arms, you will install bearings to the shells, then slip the shells into the control arms; install the control arms to the body and tack the shells into the control arms. Then remove control arms, remove the bearings and fully weld the shells.
EDIT: Welding as shown below does not distort the bore. I measured preload before and after welding and it only changed by +/-2 lnlbs across the 4 units.
A set includes: 4 shells, 4 bearings, 4 snap rings, 8 spacers. For installations to 1988 Fiero front suspension, sets will also include 8 shaft seals. Sets for '1984-1987 Fieros will not include seals as those units operate with angularity and eccentricity that seals won't tolerate.
An (simple/cheap) installation/removal tool will be available for an additional charge. It is required to install the rod ends without damaging them, but each purchaser only needs one tool.
Using the tool, bearings can be installed and removed with just a small bench vice. EDIT: And snap-ring pliers to remove the snap ring. Pliers not necessary to install.
If a few people here will commit to a set or two, I'll post this on PFiffle to see if I can get enough interest to make managing it worth my time.
EDIT: Installed photos (of a visually identical unit in a rear control arm):
The Dark Side of Will wrote: ↑Mon Mar 18, 2019 11:01 pm Installed the control arms to the cradle with the spherical bearing shells loose in the control arm sockets, then had them tacked in place and removed for finish welding.
Caveat: The suitcase TIG was broken, so they had to be tacked with a very messy wire feed.
I biased the control arms rearward ~ 1/4"... mostly because I could, partly because the rear wheels sit 1/2" forward of centered in the wheel well openings.
