No aftermarket? No problem.
Picked up a mill and lathe of my own awhile back. Benchtop stuff makes for a limited work envelope, but they’re still pretty handy.
- EFAA6142-0136-4D2C-BA27-A4150214AA21.jpeg (117.97 KiB) Viewed 2610 times
- 18AADE90-B5CA-4D8D-A99C-1BD1F1E71AB0.jpeg (104.37 KiB) Viewed 2610 times
- A1C37D2D-669F-4FB1-B2D7-9DF02BCA33F4.jpeg (97.04 KiB) Viewed 2610 times
Re: No aftermarket? No problem.
Boring out necks
Yeah, just the inlet of it though. the stock tb will take a 3400 blade.
- F6003334-8F10-4C04-AC63-5C44607FFC43.jpeg (168.55 KiB) Viewed 2600 times
- C2EE918D-E747-4829-8292-D441E66DB57B.jpeg (110.02 KiB) Viewed 2600 times
- D00A9B44-A591-4696-B8DA-646D7F928AE9.jpeg (96.87 KiB) Viewed 2600 times
I think the 3400 is 56mm. Easy upgrade
Wasn’t too bad. Opening the neck up was a little more involved.
- E01BB30B-BF14-456E-9792-0E1951E8FF00.jpeg (86.49 KiB) Viewed 2595 times
I think the point of the auto modification hobby is to fabricate stuff.
Buying off-the-shelf parts and bolting them on is boring.
I like grinding my own HSS tools; I like being able to make/modify a tool to fit the situation at hand, without any leadtime.
So I dynoed a 56-7 th from Darrel morse years ago on a stock upper. Did a before and after. Worth about 3-4 hp in my combo. 2.8
Hand grinding can be pretty rewarding. I still do it when I need an extra sharp edge or to get in a weird spot.pmbrunelle wrote: ↑Fri Jul 03, 2020 3:03 pm
Every little bit, right? I didn’t try it by itself, but it made a difference in combination with the manifold. I’m not going to guess on hp, but I did have to add fuel all over the table to maintain afrShaun41178(2) wrote: ↑Fri Jul 03, 2020 3:36 pm So I dynoed a 56-7 th from Darrel morse years ago on a stock upper. Did a before and after. Worth about 3-4 hp in my combo. 2.8
Not the prettiest thing and probably not the best way to do it, but the idea was to use what I had on hand and not actually buy any material.
- 830C185D-2146-41AE-8831-E86E1A4F837A.jpeg (133.53 KiB) Viewed 2576 times
AND.
It’s not like you can see it when screwed in place.
- 2BA327E9-6DDA-4B95-93E5-819C990AECEC.jpeg (128.1 KiB) Viewed 2575 times
If you have a stock intake also, do a test on how much volume you added.
I just have the one. I was watching a couple on ebay in case things went wrong.
I need to get some stuff like this... I have to many things I would use it for! I also still need to finish figuring out the odds and ends of the pile of 3d printer parts I bought last year...
They're great to have for smaller stuff that can't be easily bought. And if I need more swing, I can usually find somebody to help me outericjon262 wrote: ↑Sun Nov 22, 2020 6:32 am I need to get some stuff like this... I have to many things I would use it for! I also still need to finish figuring out the odds and ends of the pile of 3d printer parts I bought last year...
- lu45small.jpg (288.14 KiB) Viewed 2065 times
That's a huge machine! I'm hoping to start building my workshop middle of next year. I need to keep my eyes out for a few key parts to build a 3 phase converter, and maybe a step up transformer. I want to end up with a decent sized mill and lathe, among a long list of other stuff...
I'm a cnc service guy. I do installs, repairs, robot interfaces, etc.ericjon262 wrote: ↑Sat Dec 12, 2020 3:24 am That's a huge machine! I'm hoping to start building my workshop middle of next year. I need to keep my eyes out for a few key parts to build a 3 phase converter, and maybe a step up transformer. I want to end up with a decent sized mill and lathe, among a long list of other stuff...
Depending on what you get, it may be easier and long term economical to use a VFD to make your 3-phase (for single motor stuff anyway)
my idea, is that I'll build an idler motor converter, and use it to generate the third phase. 3 phase equipment is typically easier/cheaper to pick up at auctions, and as machines get added to the shop, the expense of VFD's goes up, but they have other advantages as well. I have time to think about it.
