the pig rig?
Re: the pig rig?
ericjon262 wrote: Thu Mar 09, 2023 2:10 pm
The Dark Side of Will wrote: Tue Mar 07, 2023 10:11 pm The throttle opening is obstructed by the throttle shaft, even at WOT... The same diameter bore is not an obstruction
dyno tests have shown that ports being stepped slightly smaller upstream make almost no difference in power, but stepped slightly smaller downstream can cause a not insignificant reduction in power.
Talking about intake ports?
A well-designed "port", which includes both the metal in the cylinder head and the metal/plastic of the intake manifold, tapers and thus accelerates the air it it travels toward the MCSA and valve seat. The edge discontinuities matter more at higher flow speeds.
it's also a TBI 350 for a Suburban. I'm definitely not setting it back up in the mill to redo it,
No, you have to CNC it
Re: the pig rig?
The Dark Side of Will wrote: Thu Mar 09, 2023 7:37 pm
I agree, but taper=/= step. A step down in cross section will cause a turbulent front ahead of the step, which will also partially obstruct flow in the port/runner/pipe, a step up in cross section causes a small turbulent area downstream, behind the step, and not into the bulk flow. in a perfect world, you don't have steps, or the steps are designed to create a thin boundary layer. What I'm referring to only occurs at joints, like the TB to manifold, or intake to head, and isn't necessarily a port design, but a function of available engineering tolerances
a simplified infographic.
I mean, how do you think I did it this time? setting a intake up on a mill, manual or CNC, has it's complications though, especially when the bores being machined aren't perpendicular to the flat surfaces on the underside of the manifold. it wasn't impossibly hard, but it was a bit of work I don't care to repeat.
Re: the pig rig?
I need to clean The Pig up and get it ready for a road trip, I have a wedding to be at in about 2 weeks, and I plan to cruise the pig up there. Originally, I wanted to drive the Fiero, but with the metal in the oil, and some parts delays, it would be far too rushed and untested for me to make a trip that far from home...
as far as progress goes, I haven't made much on the new engine. I have most of the parts, now I just need to put them together. I installed screw in rocker studs on one head, and started pulling the press in studs on the other, but didn't finish. Hopefully this weekend I can manage to at least get the short block assembled, but if it has to wait until I get back, it's not a big deal.
Re: the pig rig?
I had hoped to squeeze more in, but I had to cut alot out of my trip up north for the wedding. I'll need to make another trip out there to get to the northeast corner. the good news, on the last leg of the trip, I was the heaviest on the gas, and still managed to pull off 13 MPG, I think that's respectable all things considered, Lifted Suburban on 33's with 4.10 gears... sure it could be way better, and hopefully it will get a little better with the L31, but it's hard to say for sure. I'll post a few pictures from the journey in the next few days.
Re: the pig rig?
I put some of the pistons for the L31 in an ultrasonic sink with this cleaning solution:
https://www.amazon.com/Ultrasonic-Solut ... 5406f&th=1
I didn't follow the instructions, so I only ended up diluting it about half as much as I should have, but it has worked pretty awesome, I'll post pictures when I get a chance. very much worth it if you plan on reusing pistons in an engine rebuild.
Re: the pig rig?
the ball joints in the front axle are all messed up, so I've been slowly moving forward with getting the Dana 60 ready to go in, on the list of important stuff, I needed single rear wheel hubs, I picked up a set a while back. Since a new axle will be going in, I'm going to go ahead and put new brakes on, but one thing I've never liked about squarebody front axles, is that the rotors are pressed onto the hubs, and kinda a PITA to R&R. Enter torq motorsports:
https://torqmotorsports.com/product/gm- ... nch-wheel/
it's a caliper bracket to install larger twin piston calipers and rotors like my 2500hd has, on a dana 60.
the SRW hubs have too large of an OD for the rotor to slip over, the instructions for kit say to turn the hubs down to 7.85" at first I wasn't cool with this, but then I thought about how the stock 2500 hubs are way thinner than the dana 60 hubs. so I went ahead and turned them down.
not sure when I'll actually get it installed, but hopefully soon.
saving for further use...
https://www.offroaddesign.com/catalog/p ... egory/490/
https://www.offroaddesign.com/dana-60-c ... taper.html
Re: the pig rig?
I cleaned the rest of the pistons for the L31, Hopefully over the next week, I can spend a little time in the garage, clean up the block, and then assemble the short block.
In other, less important news, I cut down a set of stock 8 lug hubs for a 8.5" ten bolt front axle, similar to how the dana 60 hubs were cut to allow installing a GMT800 brake rotor over the hub, I'm going to try and see if I can make a similar mod to a 10 bolt front axle when I swap in the dana 60, I may have further use for the pig's stock axle.
Re: the pig rig?
I hadn't touched the L31... it needed an oil pan, when dad and I pulled the engine, it took a healthy smack'n, and I decided it wasn't worth the effort to fix it, the plan was to pull the pan off of the engine in the truck, but I also want to be able to just put it in and be done, so I bought a pan for $30 off rock auto. I'm planning on trying to get the L31 assembly started when I get off night shift next week, as I would like it to be ready to go in the Pig soon, I may even just throw the 4L80e in as is, as I know it did work before it was pulled.
Re: the pig rig?
Progress! I took a day off from working on the house, I needed a real break from it, so I went in the garage and put most of the L31 short block together. I started by spending most of the morning cleaning up the block, it had been sitting in the garage for a while, and was pretty dirty. I ran compressed air through all the oil galleries, and bolt holes, and coolant passages, then I ran a tap down every single main and head bolt hole to chase the threads. it took me several hours to get it done. then I polished up the journals and rear main seal of the crank and dropped it in.
please excuse the mess, one day I'll build a proper shop with a clean room for stuff like this...
then, I rammed the pistons in, put the cam in, and hit my first SNAFU... Ages ago, I ordered a timing set for this engine, when it arrived, I put it with the timing cover, but for some reason, I removed it from the box and tossed the box, I put the lower sprocket on the crank, and went to install the cam sprocket when I realized something was terribly wrong... looking back at the order I had placed with Summit, I ordered a step up from a stock replacement timing set for the L31, what I had in my hands was for an earlier smallblock with a flat tappet cam and not a roller cam like the L31 has... $#!+ I had no idea where I put the original gear, or if it would even work with my new timing chain and lower sprocket... I looked all over, didn't see it, then I remembered some of the parts were on the cart my Ultrasonic sink was on, I looked, and there it was! I compared it to the gear that came with my kit, if there are cut different, it's well beyond what cam be seen with the naked eye, but it had the right bolt pattern and offset for the roller cam's thrust plate to clear.
some crappy pictures of the two sprokets
I thoroughly cleaned the original gear, and put the timing set together, then I slipped my EFI Connection 24x wheel on, I'm setting this up with a DBW P59 PCM, because I'm some kind of masochist. I already have most of the parts, and it will make the 4L80E upgrade a little more streamlined.
tomorrow, I want to get the rear main seal and timing cover, oil pump, and oil pan installed, then the short block will be complete. I would be surprised if this wasn't double the power of the stock L05 TBI engine when I'm done, not that I'm looking for massive power, but I do want to be able to safely pass someone in traffic, or merge onto the interstate without having to floor it.
Re: the pig rig?
I got the rest of the bottom end buttoned up, and started cleaning and mocking up other parts for the L31. If you noticed my thread in "Advanced Tech" about dye penetrant testing, you would quickly come to the conclusion that I need another head for my engine as one of the two I checked, was cracked... well, I had another set at home, so I checked them too, but this time, all I had to do was remove some of the gasket material to see the cracks, which were quite apparent. this leaves me in quite the pickle, I have 4 heads of the same casting, 2 of which I found obvious cracks in, one I found a small crack in after testing, and one, that I didn't find a crack, but I also **only** checked the deck surface.
I'm finding reman vortec heads online in the $300 range, but, they have a $100 core, on a part that will probably cost $75 to ship. apparently the 062 and 906 castings are different, and I haven't found anyone spec'ing which casting I would be buying, so it may or may not match the 906 casting I have.
so realistically, I'm looking at about $400 each for replacement vortec heads, that I'll have to put new springs in, and modify for screw in studs.
for $450 each, I get into entry level aluminum heads.
for about $700 each, I get into pretty nice aluminum heads.
I'm not exactly looking to build a race truck here, but the stock vortecs are starting to sound like a bad idea, when they were free, they were great, but now I'd have to buy them, and work on them to make them usable, when better heads are available for not much more.
prime example here:
https://www.summitracing.com/parts/bro- ... /chevrolet
Cliff notes, Brodix 200cc aluminum heads, pair, $1209, so you're telling me for $400(over a pair of stock vortec heads) I buy them, take weight off the truck, have a better performing head, and I don't have to fuck with them?
or here
https://www.summitracing.com/parts/afr- ... /chevrolet
AFR 195, a known great head, $1200/pair. it's really hard to not give that a massive consideration.
now obviously, that leaves out the junkyard, and marketplace, but those also come with their own problems, I've already seen two or three listings with "cracked" in the description, last time I was at the JY, I saw a couple heads that were cracked... and then, even if I can find a pair of matching heads that aren't cracked(which can be hard to check at a JY), I still need to work on them to make them usable, and some of the local junkyards charge almost the price for those reman heads...
ERG. $1200 can go a long way to a junkyard LS swap, which is a debate I've been having in my head,
Pros- it's a better engine in almost every way.
cons-
JY engine, just like JY heads, is a gamble, yeah, I can check for 8 bumps in 2 turns, but that doesn't mean the engine is healthy with the L31 in the garage, I know what I have.
it's not a bolt in, I will have to get swap mounts, and deal with interfacing the engine in ways I don't have to with a SBC.
I already have some money tied up in the SBC, not much, it was a free engine, but I did have the block tanked and honed, I did buy a gasket set, headers, cam, and oil pan, and time too. while I wouldn't need to get some of those things for an LS swap, I would still probably want to do some stuff like front and rear seals, valve cover gaskets, oil pump o-ring ect. while I have the engine out, which is time and money that I already spent on this L31.
I'll just have to think real hard about it, it makes the big block on the stand seem way more appealing, but that has it's own can of worms...
Re: the pig rig?
After some serious contemplating, I had a realization, a guy at work just pulled a gen vi 454 to do an LS swap. A gen vi 454 is the latest model 454, has sequential injection, a barrel ram intake, roller cam ECT... It would be a massive upgrade over the TBI 350, and with a cam swap. Probably make comparable power to an AFR headed 350, with way more area under the curve. The other day, I went to the dudes house and checked the engine out, it was pretty clean overall, I popped two main caps, and two rod caps, all looked fine. The truck it came out of had a fat stack of paperwork, some of which were receipts for an engine replacement, so it has less miles than the truck did. At this point, I was planning on making an exhaust for the Pig anyways, so that's not really an issue. Because the 454 was pulled for a swap, it will come with almost everything I could need, even the air intake parts, and a bunch of gaskets and things. That begs the question, what about the 454 I have in the shop already? Well, it's not assembled, it doesn't have an accessory drive, and really should make a trip to the machine shop to be bored. I talked to the guy for a bit, and he said $400 and it was mine, and honestly, it makes the most sense of the available options, the plan now, is to assemble it with the 4l80 and NP205, like I was planning with the 350, that way I can build a complete wiring harness on the engine with flying leads for the PCM, power, and other chassis interface points before it even goes in. The fuel pressure regulator is mounted to the fuel rail, and the fuel line connections are the same as the TBI, when I installed the tank, I installed a 255 LPH pump as a means of future proofing the setup.
It looks like the big ticket items I will need that I wouldn't already need with the 350, are a set of headers, and possibly engine mounts. The Pig already has a big block radiator. Things I was going to need either way, were a set of driveshafts, and a way to mount the NP205 behind the 4L80.
Re: the pig rig?
The dirty 454 is in the dirty shop...
I had plans to work on cleaning it up and getting vaguely started on wiring when I got off work in the mornings, however, the AC was acting up at the girlfriend's house, and I know how to fix things, so my mornings were spent replacing a capacitor that probably wasn't bad, and then replacing a fan motor that was bad... oh jeez.
When I get off today I plan to take a few minutes to get it bolted to the 4L80, and maybe the NP205, so that I can start getting the wiring knocked out. my plan is to run the engine with a later model P59 DBW PCM, so first thing I did was remove the TB, and try a P59 throttle on it. it's the right bolt pattern, size, and everything else to bolt to the plenum, however, when the plenum is bolted to the lower intake, there's a slight problem... The DBW throttle has a coolant line that goes to it to heat the throttle and prevent it from icing in cold climates, this coolant line hits the valve cover. I think the smart plan for me, is to cut the line off of the TB I have, and make sure it's removal won't cause other problems, and if it doesn't, order a new, OEM throttle for it and modify it in the same manner. I would prefer to have a new throttle, mainly because the one I have here is an unknown part. it could be fine for 100K miles, it could already have a bad TPS circuit, I know the one in my 2006 lasted 190K miles before it went, so I would like to stick with an OEM replacement. it's unfortunate GM didn't make these with an external TPS that's easy to replace.
in other news...
FO BOAT MANES! 2 HUMP HEDS! sumbitch is gunna jump cocaine cans I tell you what!
Re: the pig rig?
shenanigan's...
the 4L80 NP305 situation isn't quite as I thought.
note, the adapter plate thickness, approximately one crumby lite beer can thick.
now, the adapter on my NP205
considerably thicker than a crumby lite beer can....
the way I see it I have 4 options...
1: a 2wd 4L80 has a longer output I could pick up another, but another is an unknown, it might be fine, it might need a total overhaul, I'd rather not overhaul one, and I know the one I have did drive ok.
2: there's a one year only NP205 input shaft that's longer, and works with the 4L80, buy one (aftermarket shafts are available) swap it into the NP 205 I have.
3: buy a different transfer case, that bolts to the 4L80, figure out the involved unknowns with that.
4: go ahead an build the doubler I bought the 205 for and put the damn thing together...
I don't like option one, lots of risk, and requires me to buy parts I kinda already have.
I don't like option 3, because it's not forward progress to an end goal (doubler)
so that leaves options 2 and 4,
option 2 is somewhat sensible, the downside is that I then need to take the 205 apart twice, once for the new input shaft, and then again when I build the doulbler.
option 4 is expensive, but means I only put the thing together the way I eventually want it, and get the benefits of the doubler off road.
the doubler would probably cost about $1300 to build the input shaft is around $300, but it's also on backorder, so who knows when I could actually get it...
I'm going to email Offroad Design and see if there's an option I'm missing.
option 2 makes some sense, it's kinda a middle ground,
