4.9 perfomance = 3800sc?????
I was googleing around and came across this website http://fieroaddiction.com/ If you notice when he talks about the 4.9 he says something like the 4.9's performance is very close to if not as good as the 3800sc's. What? I thought that the 4.9 would be closer to a 3.4TDC (which he says dosen't perform as well as the 4.9), while the 3800sc would cream a 4.9. so whats the deal? he seems like he knows what he's doing with all these swaps, but that comment through me for a loop. He does have more info on the 4.9 than the other swaps, so maybe he's a little biased toward the engine but my question is why? :scratch:
1998 Mustang GT
It's rockcrawls site...
he knows what he's talking about more than 99.9% of the people on this forum. And besdies most people who build 4.9's use J-yard motors with 1 million miles on them and attach the engine to a stock th-125 , and don't do anything with the computer. I believe Rockcrawls 88 witha 4.9 and a 4.10 ran mid to low 13's , which is more than enough to play with a stock 3.8SC which typically run high 13's low 14's The man knows what he is talking about and how to build a car.
and we shall leave it at that.
Ahhhhhhhhhh, thats right. Rockcrawl definately knows way more than me, but I still don't agree that a 4.9 is as good as a 3800SC and significantly better than a 3.4 DOHC.THE PUNISHER wrote:It's rockcrawls site...
and we shal leave it at that.
<Insert Sig Here>
I thought the 3800sc's ran high 12's to low/mid 13's depending on the driver, I could be wrong though. :dontknow: 3800SC guy's help us out with some QM times please.I believe Rockcrawls 88 witha 4.9 and a 4.10 ran mid to low 13's , which is more than enough to play with a stock 3.8SC which typically run high 13's low 14's The man knows what he is talking about and how to build a car.
1998 Mustang GT
It's going to be hard to find those times, most people don't run the 3800SC with a 4.10product1620 wrote:I thought the 3800sc's ran high 12's to low/mid 13's depending on the driver, I could be wrong though. :dontknow: 3800SC guy's help us out with some QM times please.I believe Rockcrawls 88 witha 4.9 and a 4.10 ran mid to low 13's , which is more than enough to play with a stock 3.8SC which typically run high 13's low 14's The man knows what he is talking about and how to build a car.
Jesus here we go again with this debate. so tired of it.
Yea rockcrawls site. He knows what he is doing with the 4.9. He did a few mods to his 4.9 and got it to run in the mid 13's I think. Might be on the qtr mile list. The 4 spd manuals really help out compared to the autos most people run.
THe majority of everyone else uses junkyard crap and swaps from a 4 banger to the 4.9 so it feels a ton faster while throwing 3 error codes and running 15's But in typical .nl fashion, if one person runs X time in their fiero, then everyone else with the same setup claims the same times without ever going to the track, and then month by month shave a tenth or two off that time while still never going to the track to make it seem better then it obviously is.
I know scrabblegod on here with a 4.9 and an auto got mid 14's as a best with his 4.9 while it being stock with maybe a intake or something but nothing major. He did some head porting and a larger cam and ran a 13.9 then.
Most dohcs witht he manual trannies in Fieros have run anywhere from 13.9 to 14.4 that I have seen. I beleive sinister on here with his dohc 5 spd ran a 14.1 with a completely bone stock motor sans a custom chip by himself.
THese are the facts. See them how you will.
My impression was that a reasonably stock Fiero with a reasonably good driver and about 200-210 crank HP could crack 13's. That *should* put the 3.4 TDC, 4.9 and 3800 N/A about the same level as they all make about that much power.
However, as Shaun pointed out, it can be tough to get some swaps running to their full potential. It's easier to do with the 3.4 and 3800 than with the 4.9 so the 3.4 and 3800 swaps have a tendency to run faster than the 4.9 swaps.
Jon's modded 4.9 ran 13.2 @ 102 if memory serves.
That's about what my box stock N* ran at my first time at a 1/4 mile strip with an unplugged IAT sensor.
I was also under the impression that most L67 swaps ran mid 13's, with the occasional freak almost cracking 12's.
Re: 4.9 perfomance = 3800sc?????
Jon likes the 4.9. His stock out of the box, performance is similar to the 3800sc.
He's done a ton of swaps and that's what he prefers.
product1620 wrote:so maybe he's a little biased toward the engine but my question is why? :scratch:
I ran a 13.9 with a 87GT that had a 100% stock L67 mated to a Getrag 5 speed.The Dark Side of Will wrote:My impression was that a reasonably stock
I've also driven all 3 swaps (4.9, 3800sc, 3.4DOHC) with stock engines. The performance is pretty similar in all 3. The 4.9 and 3800 are the best off the line. The 3800 and DOHC are better at anything above 60-70mph because a stock 4.9 will run out of breath at higher RPM.
88 coupe: 2.0 turbo 4. T25, w2a, meth injection
Yes, here we go again.....
I like them all (except for the 3.4). I documented the 4.9 because that's what I was into when I built the website, and because you can't find that info anywhere else on the web, at least not at that time. I'm not biased toward the 4.9, I may have been at one time, but not any more. I do prefer a V8 and I suppose I always will. I currently own one 4.9, one 3800, and four Northstars (the only one running is a Northstar, but you get the point.). Variety is key to my happiness. Well, that's one of the keys.
A STOCK 4.9 with a 2.73 4T60E trans will run 13.89. I have done it. I cannot prove it. End of story.
That is in fact "very close to if not as good as the 3800sc's" as it says on my website. I'm talking about a STOCK 3800SC, once you change the blower pulley it's no longer stock. I really don't think there is a stock 3800SC going a whole lot faster than 13.9, but I could be wrong. Surely there is no series I that can match that.
Once you get into modifying the engines, all bets are off. 3800 will almost certainly come out on top because of aftermarket support.
Then there's the differences in trans ratios and such. I built two seemingly identical 3800 SC cars, the only difference being one car has 3.08 gears and a high stall converter and the other has 2.96 gears and a stock converter. The first car is consistently .5 second faster.
60 degree V6s go directly to the scrap yard unless I can find some fool to actually pay money for them (suckers). I do have four of them here now, one actually still runs well, two with spun rods (what a surprise) and one completely seized (no doubt from a spun rod bearing). Hey, did I ever tell you guys about all my experiences with spun rod bearings on V6-60s? Ah well, not enough time for that tonight.
Sorry for the semi-long post. For some reason I felt like I had to explain myself instead of just telling people to piss-off like I should. Oh, Fastback86, you can piss-off.
thank you for takeing the time to explain it. I wasn't at all trying to start a debate I just wanted a clear answer, because it seems when people talk about the 4.9 and 4.9 owners its almost always in a negative way and they don't take the time to clarify them selves by saying that their refering to douche bags who dump in a JY motor.
1998 Mustang GT
Huh, cause I thought I read about a 4.9l spinning a rod bearing right after his 13.9. Oh yah, it's becuase I did.
And it isn't hard to prevent your 3.4 from spinning bearings. Synthetic oil every 3k, a nice filter, and limit the runs to 6500rpm. Still sky high compared the the 4.9l, and just as reliable.
Every criticism, judgment, diagnosis, and expression of anger is the tragic expression of an unmet need. -Marshall Rosenberg
