Let's play Name That Flange
Here's the deal. I'm trying to get an ident on my turbine outlet flange so I can get some sort of V-band clamp for the thing, but I'm not sure that that's possible. It has the right angles for a V-band, but the flange itself is too thick I believe. Here's the pics:
Anybody know?
Anybody know?
I think you just need a clamp and a flange for your downpipe. Take out a set of calipers, measure and call up a turbo house and order the size you need.
http://store.yahoo.com/cheapturbo/stainsteelt31.html
Should be <$50 since you dont need the tig welded part.
so you are using a Diesal turbo?
How are you usre its actually a gt35 wheel? I know you bought it on ebay so who knwos what you really got. You hav eno way to verify it.
That thing dwarfs that GN turbo. I think that would haev been a better sized turbo for your 4 banger then that huge thing. I am thinking it might not even spool.
good luck with that project
