4 . 9 head gasket swap
Yep, gatta do the head gaskets on my car so, I'm gonna take a bunch of 4point9 pictures through out the job to entertain all you 4 . 9 lovers here. :la:
Seriously though. I'm gonna try to make an informitive thread with some good pictures, both before and after cause I am gonna do some detail work too. Starting tomorrow.
Peace out :salute:
Peace out :salute:
All went well. I got to drive it for the first time today. Although it was just in the yard, it cranked up first turn idled fine and sounded good. Clutch iwas great, everything. You would not know that it had a blown head gasket, but a compression check confirmed it. So we pulled the motor and stripped it down to the block. I'll post pics in a little bit once I resize them and get som motivation. The internals of the engine are clean as a wistle.
- crzyone
- JDM Power FTW
When I pulled apart my "good" 4.9 it also looked like the head gasket was eaten through in places. Have to be sure to use fresh coolant in a motor with an aluminum block and iron heads. The older the coolant gets the less anti corosion properties it has. Alot of "cadillac" owners don't really know this or care.
A complete gasket kit was $300 2 years ago for my 4.9 which didn't include the oil pan or timing cover gasket (another $100)
Expensive motor to work on.
Go here to see some pics. I dont have any where to host them.
http://www.fiero.com/forum/Forum1/HTML/049836.html
Quit being a lazy ass panzy and go take a look.
The heads are getting machined, magnafluxed and acid dipped as well as a valve job. Should be back tomorrow for reassembly.
http://Old Europe.hostkansas.com/pffimages/DSC01302_1.JPG
http://Old Europe.hostkansas.com/pffimages/DSC01304_1.JPG
If you know how to use ftp, I will hook you up with webspace.
I actually make it a point to not go to fagland for anything.
GmetalGT wrote:Quit being a lazy ass panzy and go take a look.
http://Fagland.hostkansas.com/pffimages/DSC01302_1.JPG
http://Fagland.hostkansas.com/pffimages/DSC01304_1.JPG
Here are the pictures.
This is the top of the motor after pulling the intake and valve covers.
![Image](http://memimage.cardomain.net/member_images/1/web/613000-613999/613501_41_full.jpg)
Check out how clean the top of the pistons are. There was NO cleaning done! I had just pulled the head off.
![Image](http://memimage.cardomain.net/member_images/1/web/613000-613999/613501_42_full.jpg)
This is how I painted the top end. Gunmetal and flat black.
![Image](http://memimage.cardomain.net/member_images/1/web/613000-613999/613501_39_full.jpg)
![Image](http://memimage.cardomain.net/member_images/1/web/613000-613999/613501_40_full.jpg)
Heads came back from the machine shop yesterday after noon. They got shaved, magnufluxed and acid dipped. I have not seen them yet but I asked MTA to snap a few pics for my collection.
I also forgot to mention that we did a little work to the heads. Didnt have the time or money to do a full port job but we did grind down all the sharp edges in the heads to make them all smooth. REally would have like to do a full port job, but oh well.
