My new obsession for the week.
BC2002SS
Post by BC2002SS »
oh and did your dad get the birth certificate that came from slp?
2002 Camaro SS
1986 Fiero GT 3800SC 4T65E-HD
slp 1.8 rockers, slp headers, northstar throttle body, Z06 MAF,3.3" pulley,160 drilled stat,
12" Corvette brakes
1.81 60' 13.004 @102
new best 1.939 60' 12.909 @ 104.50
BC2002SS wrote:Aaron do you have any pics of the engine, engine compartment. mostly of the passenger side head at the front, trying to find out if it has the ls6 block that some had
LS6 block sounds nice, but without the rest of the LS6 stuff...hehe.
Here's the closest I have, I can get closeups over Thxgiving:
Didn't EVERYTHING go to the LS6 block once they started producing it?
S8n
Post by S8n »
Nope. GM had enough leftover LS1 blocks to cover almost all except the last few months of production. My '02 still had the LS1 block.
-Chuck
chukjagr@hotmail.com
'87 GT *Now can be seen at V8Archie's!* www.fotki.com/8balls
S8n wrote:Nope. GM had enough leftover LS1 blocks to cover almost all except the last few months of production. My '02 still had the LS1 block.
Pretty off guessing, but by that account I might have the LS6 block, because mine was one of the later LE's produced, being #2876 of some 3100.
BC2002SS
Post by BC2002SS »
only sure way to tell is to get the numbers off the block aganist the firewall on the drivers side
2002 Camaro SS
12" Corvette brakes
What are the differences in the LS1 and LS6 blocks?
I'll check it when I go home next.
BC2002SS
Post by BC2002SS »
different stronger alloy and larger holes in the main webs in the block and better oiling. looking for pics to help identify ls1
number 12561168 is the ls6 casting number
2002 Camaro SS
12" Corvette brakes
BC2002SS
Post by BC2002SS »
quick check to find out if you need to look further, is to look here.
look for the two bullseyes as seen here.
if you have them it's an LS1 stop looking if it looks like this it might be an LS6 check the numbers on the back of the block on the drivers side.
2002 Camaro SS
12" Corvette brakes
BC2002SS wrote:different stronger alloy and larger holes in the main webs in the block and better oiling. looking for pics to help identify ls1
What's the alloy difference?
The bay-to-bay breathing windows went from being machined in to being cast in place. These are important to power... they're worth over 25 hp on a Northstar.
BC2002SS
Post by BC2002SS »
not positive of the differences will try to find some of that stuff it was a long time sense this was talked about on the camaro sites. I do remember it had something to do with the Mexican plant that the LS6 was cast in
2002 Camaro SS
12" Corvette brakes
BC2002SS
Post by BC2002SS »
2002 Camaro SS
12" Corvette brakes
