eh, the process isn't that much different than actually boilingit on the stove - the difference is in it heats up the egg too fast - it was submerged in water btw..
i got a kick out of it - had to share, that is all
hell you can get sparks if you have two pickles touching
its a ceramic soup bowl btw -
you need a photo of the rack?
"Inside the microwave is a removable metal rack. As most people have been taught, it is not wise to put metal in a microwave as it can cause sparking. However, this metal rack does not cause that problem. The manufacturer advises that the metal rack never touch the microwave’s sides or bottom during cooking. Also, make sure the metal rack is not in the oven unless it is being used. There are plastic spacers affixed to areas on the rack to keep it from touching the microwave walls. The rack mounts inside the microwave are also constructed from plastic. This rack will accommodate two dinner plates, so that a total of four dinner plates can fit in the microwave at the same time (2 on the rack and 2 on the floor)."
any two highly conductive objects touching inside a microwave is bad - that includes the side panels of the microwave, but they have to touch..
hell you can microwave papajohns garlic butter packets with the foil lids, just don't let two of them touch
donk_316 wrote:Dont need to change my mind dude... we nuke food in metal pots all the time at work. Just not using tin foil lids or the like.
That works fine because it's in the center. You can put a lid on top of the pot too. All it will do is bounce the microwaves off and blow out the magnetron. You can safely do that with a cup of water in there... The cup of water will heat up and whatever's inside the closed pot will stay cold.
Kohburn wrote:The manufacturer advises that the metal rack never touch the microwave’s sides or bottom during cooking. Also, make sure the metal rack is not in the oven unless it is being used. There are plastic spacers affixed to areas on the rack to keep it from touching the microwave walls. The rack mounts inside the microwave are also constructed from plastic.
Have you guys made plasma balls?
Just put small burning things in your microwave and turn it on (toothpicks, small scraps of balsa). You may have to try it a few times. If you overturn a pyrex bowl a bove your plasma generator, you can keep the plasma going inside the bowl.
It makes the coolest electrical humming / buzzing you could ask for. And if you're nerd enough, the ball of plasma'll be enough to cream your shorts anyway.
Ha ha, me and my friend did the egg thing when we were like 12 or 13. Just a hissing noise, then kind of an anticlimactic pop. And the mess, of course.
Funny you should mention beetles, too. Just had that one happen today...
