Non-Fiero Technical Discussion?
Moderator: ericjon262
Falcon4
Post by Falcon4 »
We have a Non-Technical Fiero Discussion... but a non-Fiero technical discussion forum, perhaps? :thumbleft:
I need to poke peoples' brains about wiring diagrams and part information for some ancient Dodge parts. :P
Or should I just ask? :scratch: I don't want to get reamed out for posting in the wrong forum though.
edit: The Dodge isn't mine. :la:
'87 Fiero GT, Automatic, 153... 156... 157... 158... 161k... 163k... 165k... 168k... SHIT I LOST COUNT
we have an other cars section, cant you read?
Don't expect a ton of help after the way you acted before when people gave you advice...
Falcon4
Post by Falcon4 »
Series8217 wrote:we have an other cars section, cant you read?
Yes, I can, but often that means "let's compare engine sizes of our other cars". Not "anyone plz help me with my car fixings"... just kinda makes sense to me. :scratch:
crzyone: Obviously forums fail at diagnostics, but I'm not asking for diagnostics here, I'm asking for knowledge. I know what the problem is, I just need to know how to fix it. :P
84fierotrevor
Post by 84fierotrevor »
Lower your car :la:
Falcon4
Post by Falcon4 »
I can do that by just seating two people in it. :la:
Fastback86
Post by Fastback86 »
Buy a Honda.
<Insert Sig Here>
Xanth
Post by Xanth »
Fastback86 wrote:Buy a Honda.
ROFL :thumbleft:
Its funny because its true.
Falcon4 wrote:I know what the problem is, I just need to know how to fix it. :P
That's part of the problem. If it's an old Dodge, you CAN'T fix it, you can only work on it.
Falcon4
Post by Falcon4 »
Well, I got it to start and run without flipping ghetto redneck switches... :thumbleft:
And I converted the ghetto-ass gauge voltage regulator to a silicon beauty with a little help from Radio Shack. No more pegged gauges for us, yay!
(I hope... stupid wiring.)
Now to figure out what that smoke is that comes from the dash when the engine's running with the headlights on... :scratch: :salute:
Mach10
Post by Mach10 »
I got my money on the "Silicon Beauty" slowly but steadily melting the insulation off your wiring. :salute:
It's a dodge. They have wiring issues, always have, always will.
Look for a burnt connector behind the fuse panel; once the contact corrode, they tend to start to smoke when you load them.
Falcon4
Post by Falcon4 »
The silicon beauty takes from the 12 volts and makes a glorious steady 5 volts out of it, all at a low enough current as to where no smoking is going to happen. Plus, I already checked if it was getting hot. :thumbleft:
I've seen some of those loose connections in that wreck too. That's what destroyed the ammeter in the dash, loose connections made for not happiness with the connection, hence hot rods, and hence burn-melty. The meter would still work if I cleaned the contacts, but fuck if I want to go trusting it with the whole power system's current... :P
I still don't see how headlights could pull enough current to cause smoking. I think it's something shorted to ground. When the lights are on, the dash indicators all light up dimly at the same time - that can't be a good thing. With a damn near total lack of fused connections in that truck, it wouldn't surprise me a bit if the stupid thing was shorted...
But hey, we're getting into that diagnostics thing again... :la:
Mach10
Post by Mach10 »
Do the math, brohab.
75w of bulb on 12v is 7amps... Times 2.
That's more than enough to smoke a wire--especially if the connections are bad.
stimpy
Who wants Ice Cream?
Post by stimpy »
My Fiero is now a Finale. The end.
Falcon4
Post by Falcon4 »
stimpy wrote:www.allpar.com
http://www.allpar.com/forums/index.php?showtopic=91188
And I guess you're right, I didn't know amps went up as volts went down. Ohm needs to go choke on a dick because that equation is just too complicated to figure out. Can't he just do it in Javascript for us morons to figure out? :la:
You sir, are an idiot.
Falcon4
Post by Falcon4 »
p8ntman442 wrote:
Falcon4 wrote:Ohm needs to go choke on a dick because that equation is just too complicated to figure out.
I guess you couldn't notice the sarcasm dripping from that quote of yours... good on you, you fail at teh internets! :thumbleft:
You sir, are still an IDIOT. :tool:
it was worth repeating.
