I pulled the one out that was in the car and installed the other and still no charging.
I cleaned all of the terminals really well and actually put a new connector on the heavy red wire for the battery. I know that the 2-wire plug is sitting well on the correct spot and making good contact.
I tested resistance between the alternator lug and the battery lug and got 0.3 ohms resistance. That cable is good.
The battery light comes on when you turn the ignition on and stays on after the "bulb test" circuit does it's thing.
What could be causing the alt to not charge? What do the two wires on the alternator do? I know that one is connected down a few inches on the battery wire, but what does the smaller brown wire do?
Also, is there a way to do a diode check with a digital multimeter?
Thanks!!
![Image](http://www.clubredline.net/images/chrisnelsonsig.gif)
Club Redline - Northern Minnesota Sport and Modified
