I have Konis on order and I am getting ready to place an order with WCF for a front spring/rear coilover set. I am also going to order "Urethane A-Arm Bushings" for the rear and "1984-1988 front A-arm bushings with grease fittings" for the front as well as "Rear camber adjusting bolts (1984 - 1988)". Is there anything else I should do at the same time?
Steve AT 88GT DOT com
urethane and suspension parts
I think you have it just about covered, now is the time you gotta go through all of your componant and make sure they're not owrn out, ball joints, tie rod ends, toe links, etc...
And no strut tower brace, we make them at WCF and we will tell you to your face they won;t do a damn thing except look bitchen, thats what they're for - peel back your trunk carpet and you will see a HUGE strut tower brace from the factory all ready built in![Smile :)](./images/smilies/smile.gif)
