OK, kidz-
Which loctite should I be using on flywheel bolts? I've seen some say blue, and some say red. I'm guessing that either is fine, but does anyone have any strong thoughts one way or another?
Which loctite?
I personally use red - cuz as teamsleep says, you really don't want something storing the kinetic energy of a big bore magnum hunting rifle bullet coming free.
I've had to mount and unmount mine a couple times, and removing it wasn't a problem at all - use a good socket and a breaker bar, and it'll come right out.
