New GM LS9 Supercharged Vette ZR1 engine
'Cause they didn't need thicker liners. DO, however, note that it uses a smaller bore than the LS7 because the LS7 bore size couldn't take the boost for production reliability.Series8217 wrote:I can't wait to start seeing these things on the road.
That block sure looks sturdy! 6-bolt mains FTW!
Interesting that they went with thick aluminum bore walls but very thin iron liners. Keeping the weight down?
The "flying butress" main bearing bulkheads with the cast in bay-to-bay breathing windows are things of beauty.
The "Dual Gerotor" oil pump... is one stage scavenge and one pressure?
Last edited by The Dark Side of Will on Wed Jan 09, 2008 6:11 pm, edited 1 time in total.
It is a badass engine for sure, but I gotta be honest when I say I'd have rather seen a high output N/A 32 valve 6.2l, like an 8,000rpm 100hp/l engine. It would have really payed tribute to what the ZR1 was back in the day.
"The engine produces 90 percent of peak torque from 2,600 rpm to 6,000 rpm."
Damn, that's impressive!
Also, Will, it has a twin disk clutch setup too :thumbleft:
The Dark Side of Will wrote:The first Corvette to bear the ZR1 name was actually back in the '60's...
Why does everyone want overhead cams?
cause ferrari uses them, and most BADASS motors from GM have been dohc's.
- crzyone
- JDM Power FTW
It is really impressive how much power they can get from a 2V pushrod engine. If they can get 500hp NA from the LS7, I imagine they could get a lot more from a 4V DOHC design.
The supercharger probably adds the weight that a set of DOHC heads would. If they wanted to, they could make the heads a lot smaller than the old style DOHC heads and use hollow cam shafts as well.
A 600hp DOHC aluminum V-8 from GM would probably be a better showcase of what GM could do.
I'm starting to think that's the point, GM wants to prove that pushrod technology is not dead and that they can build an OHV engine thats just as powerful as DOHC engines. I think GM and Dodge want to keep the old school (as it were) OHV style going just to be different than all the other car companies. They've proved they can do DOHC just fine with the N* and the N* SC (for example), and yet they still use the OHV engines.crzyone wrote:It is really impressive how much power they can get from a 2V pushrod engine. If they can get 500hp NA from the LS7, I imagine they could get a lot more from a 4V DOHC design.
<Insert Sig Here>
GM doesn't want, or need, to prove anything to anybody. They keep the pushrod design because it's cheaper, they modify existing designs instead of creating all new designs, it weighs less, it's a tighter configuration for the displacement, and it offers a performance curve that most people really like.
It offers a performance curve that most people THINK they really like. Most people don't have any experience with a DOHC 8...Aaron wrote:GM doesn't want, or need, to prove anything to anybody. They keep the pushrod design because it's cheaper, they modify existing designs instead of creating all new designs, it weighs less, it's a tighter configuration for the displacement, and it offers a performance curve that most people really like.
No, the people know they like it. As I said in the other thread, I got the chance to drive a 300wtq TGP, which is a torque monster. It felt like it'd walk away from my car, it felt so much stronger. Then at the track, I posted consistently better times, by a half second! When Grandpa is getting on the highway and hits the gas in his 3800 Buick, it just goes. It doesn't make a lot of noise, he doesn't have to rev it sky high, it just does its thing. Sure I love watching the tach climb up to 4,500rpm just to get on the highway with traffic, but most people don't. The DOHC gets semi loud with induction noise, the pre-3500 power isn't that great comparatively, and with an auto it'd suck worse. No such problems exist with the 3800, even the 3X00. While they don't make the same amount of high end, the low end feels much stronger than the DOHC (Even though in reality it isn't).Indy wrote: It offers a performance curve that most people THINK they really like. Most people don't have any experience with a DOHC 8...
honestly it looks like most poeple would like this curve inclued DOHC fans.Indy wrote: It offers a performance curve that most people THINK they really like. Most people don't have any experience with a DOHC 8...
And it would also blow away a few DOHC v8 designs in a straight and through turns.
let the chart do the talking.
![Image](http://www.corvetteblogger.com/images/content/071607_2.jpg)
note this is the ls3 and if the curve on the ls9 is similar, it should not be a short rpm stump puller engine, it has a very high and relatively flat torque curve making 75% of its peak at all rpms in its range.
Why the heck would GM use a Dynojet? Convenient source of relative break in data?
I reiterate... why's everyone so wrapped around the axle about OHC's vs Pushrods.
Pushrods are not relegated to low RPM... just lower than an equivalently built OHC setup. The LS7 revs to 7000 RPM... with pushrods and a 4 INCH (!!) stroke. Drag race engines with pushrods top 10,000 RPM; NASCAR engines run to 9500 and handle 500 mile races, which is twice as long as any F1 race.
It's just this compromise:
Pushrods:
Pro:
Light weight
Compact
Simple
Cheap
Con:
Reciprocating mass
Can not vary cam phasing independently (except it's done on the Viper...)
OHC:
Pro:
reciprocating mass
independent variable cam phasing
Con:
Heavy
Bulky
Complex
Expensive
I can NOT see why a design that focuses as obviously on bang for the buck as the Corvette's design would choose OHC over pushrods. Ferrari doesn't design to a price point. GM does. Pushrods should surprise absolutely no one and absolutely no one should be upset at their use.
Pushrods:
Pro:
Light weight
Compact
Simple
Cheap
Con:
Reciprocating mass
OHC:
Pro:
reciprocating mass
Con:
Heavy
Bulky
Complex
Expensive
