custom intake for 3.4dohc turbo
Kohburn
FierHo
Post by Kohburn »
Oversteer wrote:Can you give me the contact info you have?
just as soon as i test it out with the fiber - don't want to give out bad information
Oversteer
Post by Oversteer »
Cool. Thanks buddy
He called the shit poop
donk_316 wrote:
Kohburn wrote:
Oversteer wrote:Are you just using the resin? No fibre material?
yeah I'm using some fiberglass cloth in mine but the resin itself has a 10,000psi rating
when its all done i may make a ceramic mold of it and cast aluminum copies
Do it. I wanna run one.
I'd buy one too, and would be willing to spend nearly $500 for it. Any more than that and I'll shy away becuase I could do it myself for around $100.
donk_316
Booooooost
Post by donk_316 »
aaron wrote: I'd buy one too, and would be willing to spend nearly $500 for it. Any more than that and I'll shy away becuase I could do it myself for around $100.
Aaron...here is a little advice from me to you regarding negotation. Never ever say what you just did.
Kids these days...Think they know everything.
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
whipped
Post by whipped »
Getting it cast in aluminum might be your best bet. I think you're going to have separation problems with the aluminum and epoxy.
S8n
Post by S8n »
whipped wrote:Getting it cast in aluminum might be your best bet. I think you're going to have separation problems with the aluminum and epoxy.
Aluminum heat-soakes too easily though. It'll be worth some trial and error to get the aluminum and epoxy working.
-Chuck
chukjagr@hotmail.com
'87 GT *Now can be seen at V8Archie's!* www.fotki.com/8balls
aaron...here is a little advice from me to you regarding negotation. Never ever say what you just did.
Why, becuase I offered him a price I'd be willing to pay?
This wouldn't be for me anyways, it'd be for my friend who is planning a 3.4 Fiero as well.
donk_316
Booooooost
Post by donk_316 »
aaron wrote: Why, becuase I offered him a price I'd be willing to pay?
Exactly. Negotiation is an art form. But whatever.
1991 Skyline GTR
(OO\ SKYLINE /OO)
I don't need to negotiate. If I want the intake, and I trust his skills, and I have the money, I will gladly pay what I think it is worth, which IMO is "up to" $500.
donk_316
Booooooost
Post by donk_316 »
aaron wrote: I don't need to negotiate. If I want the intake, and I trust his skills, and I have the money, I will gladly pay what I think it is worth, which IMO is "up to" $500.
Nevermind. Its cool.
1991 Skyline GTR
(OO\ SKYLINE /OO)
Kohburn
FierHo
Post by Kohburn »
the epoxy i'm currently using maintains a bond strength of 1000psi at 450*F so it shouldn't seperate without a nitrous backfire
Kohburn
FierHo
Post by Kohburn »
there are two options really - cast aluminum and cast plastic
the materials for cast plastic are more expensive
but the materials to make the mold for cast aluminum and the equipment to melt the aluminum are more expensive
so really its all about quantity as to which is more feasable
but either way should be able to keep the price down to be a bit more reasonable.
---- may as well toss in an update
used some spray foam again last night to bond the green foam peices together and to fill in that groove on the top and build up a little more..
I'm going to hold off on pics untill its finished and ready for epoxy covering - after that no more pics till its completed
whipped
Post by whipped »
well I'll see your 1000psi, and raise you 10,000psi for thermal expansion :la:
F/A = E*d/L
d = c*T*L
so
F = E*c*T*A
E is young's modulus
c is coefficient of thermal expansion
T is rise in temperature
A is cross sectional area
Kohburn
FierHo
Post by Kohburn »
F/A = E*d/L
d = c*T*L
so
F = E*c*T*A
so which one do you think is going to expand more.. solid aluminum of the 6061-T6 variety, or aluminum filled epoxy with a 10,000psi tensile strength (i'd have to check its spec sheet to see if they privided anything for thermal expansion, but i doubt they did)
and do you think that the expansion will exceed the epoxies elasticity? I don't - granted some epoxies are very brittle, most I work with are not
I also higly doubt the intake will ever even see 200* let alone 500* that the epoxy is good to
whipped
Post by whipped »
Kohburn wrote: so which one do you think is going to expand more.. solid aluminum of the 6061-T6 variety, or aluminum filled epoxy with a 10,000psi tensile strength (i'd have to check its spec sheet to see if they privided anything for thermal expansion, but i doubt they did)
The aluminum, easily. Plan on cycling the intake from 30 degrees to engine overheating (250+) temps.
Kohburn
FierHo
Post by Kohburn »
whipped wrote: The aluminum, easily. Plan on cycling the intake from 30 degrees to engine overheating (250+) temps.
the intake never gets that hot - it has ambient air flowing through it non stop cooling it
granted under a lot of boost it'll see higher temps but its still doubtful it'll ever see temps over 200
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
make a spacer that is made out of ultra high molecular weight plastic. That will keep the engine heat from transfering into the intake as much. (martha stewart cutting board from kmart is good for this).
Kohburn
FierHo
Post by Kohburn »
its not necessary
Aluminum or plastic I could honestly care less which. And remember also that you could have quite a few of the W-body 3.4 people interested as well, even though it is a short runner intake. I say go for it.
Kohburn
FierHo
Post by Kohburn »
ok couldn't help myself - here is a pic of the foam covered in silicon
